set options for a multi-select custom field via script
HanQiao July 7, 2024
Hi Team
Im trying to add options to a multi-select custome field via Python script:
def set_field_options(field_id, options):
    url = f'{JIRA_URL}/rest/api/2/field/{field_id}/option'
    for option in options:
        data = { 'value': option }
        response = requests.post(url, data=json.dumps(data), auth=HTTPBasicAuth(USERNAME, API_TOKEN), headers=headers)
I always got an error like:
Failed to create option 'REPLACE LMD' for field 'customfield_10169'. Status code: 400, Response: {"errorMessages":[],"errors":{"fieldKey":"Field key 'customfield_10169' is not valid"}}
or
Failed to create options for field 'customfield_10169'. Status code: 400, Response: {"errorMessages":["Invalid request payload. Refer to the REST API documentation and try again."]}
Could you help me to solve the problem or give me a API documentation for reference?
Thanks a lot
Joseph Chung Yin
HanQiao July 8, 2024
@Joseph Chung Yin
Thanks a lot.
This reference is helpful.
FREE
