use smart value / variable in Workflow post function
felix.weber
August 15, 2021 edited
Basic question: is it possible to use smart values in Workflow-post functions to set the value of a field ?
I know how to set a static value to a field using post-functions but I won´t get it to work using smart values - I have just tried as in jira automation to enter {{issue.reporter.properties.office}}
as a result exactly "{{issue.reporter.properties.office}}" will be the value of the field
bit more information:
currently I am testing the atlassian user properties, set via API (currently just via Postman)
Finally I am able to set a user property: {{issue.reporter.properties.office}}
content of this smart value is: {office=Munich}
I want to set this value when a issue is created using a Jira Workflow instead of a Jira Automation.
Sean Young October 25, 2023
I also tried to use smart values in a Zendesk workflow comment and it didn't seem to work.  Trying to find if they are supported there.
Samet Yildiz March 23, 2022
Hello Felix,
I tried it also with different variables but without success.
I think it is not possible to use smart values or any other expression expect %%CURRENT_DATETIME%% and %%CURRENT_USER%%
Why don't you want to use a Jira Automation?
Alternatively you can use Apps like JWT oder JMWE. Its possible to set variables with them..
Regards
Sam
Job Burg
August 1, 2023
Because they cost money ;).
Like • 4 people like this
Upcoming Jira Service Management Events
