G’day Atlassian community!
Update on below announcement (28th March'23):
We had earlier announced that the “Introduction of two new permissions to replace Browse Project permission” was planned for release on 31st March ’23. Since then, our customers and partners have raised a few questions regarding the rollout, which we are still in the process of addressing. As a result, we have decided to NOT rollout this change on 31st March ’23 for Jira Cloud.
This means, Browse projects permission will continue to work as it is, and the two new permissions won’t be introduced until further notice.
Meanwhile, this work is still a priority for us, and our team is evaluating all the questions and concerns mentioned in the comments. This process of evaluation will take a few more weeks. Following the evaluation, we will inform you about the revised timeline for rollout, well in advance.
Thank you for your feedback. If you have any questions, please drop them in the comments section. As mentioned earlier, please expect more communication on this in upcoming few weeks.
Thank you
+++The content below is outdated as of 28th Mar'23, please read above for the latest update on replacement of Browse Project permisions with two new permissions +++
Update on below announcement (4th Oct'22):
On Aug 16, 2022, we announced “Introducing two new permissions to replace Browse Projects permission“. It was planned to be released by end of September 2022.
We’ve since received feedback from many of you on this being a fundamental change in how permissions behave, and the requirement of more notice period to adjust with the change. As a result, we have decided to NOT rollout this change on Jira Cloud for next 6 months, till 31st March’23.
This means, Browse projects permission will continue to work as it is, and the two new permissions won’t be introduced.
Meanwhile, our team will evaluate the different cases mentioned in the comments to ensure all of them are addressed properly. We will inform you well in advance about the revised timeline of the rollout of this change.
Thank you for your feedback and apologies for any confusion caused by the earlier announcement or this revision of the timeline.
If you have any questions, please drop them in the comments section. We will keep you posted.
Thank you.
We’re excited to announce the addition of 2 new permissions to replace the “Browse Projects” permission. This is meant to give Jira administrators more fine-grained control over who can view the projects and issues.
As you may know, the “Browse Projects” permission has dual functionality. It is used to check both
if a user can view projects
and if a user can view the issues within the project.
In other words, it can be used to act at the Project Level e.g. permission to view the projects directory, and at the Issue Level e.g. the ability to view an issue. Since all the other permissions either work at the Issue Level (e.g. "Edit Issues") or at the Project Level (e.g. "Administer Projects"), the current way of working with the “Browse Projects” permission is unique and problematic.
By splitting the “Browse Projects” permission into two, we can give users more fine-grained control over Jira’s permissions. Each of the new permissions can have its own distinct role and that’s what we have done.
“View Projects” is a project-level permission for viewing projects in Jira. It is the permission to view the projects directory page and the ability to select that project in various dropdowns such as in JQL.
“View Issues” is issue-level permission for viewing the issues within a project.
Therefore, “View Issues” can be used to control who can view issues within a project and “View Projects” can be used to control who can view projects in the projects directory.
Since we have introduced these two new permissions that fulfill the same purpose as the “Browse Projects” permission, we are deprecating the “Browse Projects” permission. We will stop supporting it eventually.
Firstly, you will notice some changes to Jira’s permissions scheme page. These are as follows:
The “View Projects” permission will appear under the “Project permissions” category, with a “New” tag.
The “View Issues” permission will appear under the “Issue permissions” category, with a “New” tag.
If a grant is made to “View Issues” permission, the corresponding grant should be added to the“View Projects” permission as well. For eg: If you want the “administrators” group to have access to issues for a project, the grant has to be made to both “View Issues” and “View Projects” permission.
A “Deprecated” tag will be shown next to the “Browse Projects” permission. This means we strongly encourage you to avoid using the “Browse Projects” permission. Instead, use the “View Projects” permission and the “View Issues” permission.
If you were to use the “Browse Projects” permission, internally it would still translate to “View Projects” and “View Issues” permissions, but that support will go away after some time, so please don’t use it!
Getting information on permissions of a project will return information on “Browse Projects” as well as about “View Projects” and “View Issues” permissions. However, since support for “Browse Projects” permission will eventually be withdrawn, it is highly recommended to use “View Projects” and “View Issues”.
We will roll out this change to all of our customers in phases over the next few weeks. Since this change involves a deprecation, we strongly recommend and urge all customers to plan for and adopt the above changes. Meanwhile, we welcome feedback from you.
Here are some screenshots from the Permission Schemes page that indicates the changes mentioned above.
Thank you in advance for working through these changes and for your continued support. Please reach out to us in case of any concern by commenting on this post.
Best,
Varad Pingale
Jira PM
Varad Pingale
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
58 comments
