Sign up Log in
Automate online site-backups for Jira and Confluence without programming
71 comments
Avishay Silverman
October 31, 2021
hello,
I try to run the script on Win and I failed,
could some get help here ?
thanks
Aaron Geister_Sentify
November 23, 2021
@K. Yamamoto  If you are using Admin Kit for Jira Cloud is there a way to automate the download and export it to Google Drive for storage or does this automated backup just keep the newest version for restoration if an issue arises?
Like # people like this
Shraddha K Goswami
December 9, 2021
Very useful, thank you.
Sorry to revive this thread but is it possible to restrict Jira API to any specific project?
Thank you.
Léo Badia
December 14, 2021
@K. Yamamoto Like @Aaron Geister_Sentify I would love to be able to automate the download with the admin kit. I tried to use the powershel script from https://bitbucket.org/atlassianlabs/automatic-cloud-backup/src/master/ but I'm having trouble making it work and the Adminkit is already pretty good, it's just missing the auto download function.
Shiv Sharma
When I run the rule, it fails with a message that the IP address has been rejected because it is not on the allowedlist.
What IP address should be added to the allowed list? Thanks!
Shiv Sharma
Admin Kit for Jira gives the following error when trying to use it after installation.
Unexpected error in app
An error occurred while trying to load this app.
  • Refresh app
K. Yamamoto
March 22, 2022
Re: Admin Kit -- it doesn't work with the IP Allowlisting since the outbound IP address ranges from Forge apps are not disclosed at the moment. Vote for FRGE-276 to make it possible.
Re: Admin Kit -- the download automation is out of its scope. Refer to FAQs for more details.
Re: Jira automation -- The error regarding the basic authentication method should probably be due to the incorrect configuration.
David Lee March 30, 2022
@K. Yamamoto I looked at the Admin Kit apps but once you have IP whitelisting enabled, they can't work.  Do you have a workaround that @Ali Alnakeab mentioned with the Automation not working using basic auth since it is deprecated?  Not sure how to add the API token as a header.
K. Yamamoto
March 31, 2022
@David Lee Consider voting for FRGE-276 to make Admin Kit work with the IP Allowlisting.
If you issued the API token at https://id.atlassian.com/manage/api-tokens and still saw the deprecation error, the exception message is a red herring. You need to properly encode the credentials as described at (1-2) in the article.
ashleytse April 3, 2022
may i know if this work for Next-Gen project? if i want to create backup for datacenter version
thanks!
Rajesh Munshi April 4, 2022
It's possible Setup automatic backup for Jira support instance and Confluence support instance..
If possible please give me how to do.
Hi Yamamoto,
First of all Thank you , after select Scheduled and click A CRON expression  but now showing (simply run the conditions and actions without providing issues") option please help me how to configure automatic backup.
Like ashleytse likes this
K. Yamamoto
April 10, 2022
To comply with the security requirement of Marketplace, I am deprecating Admin Kit’s automated backup feature. Please refer to Important notice - backup feature deprecation for more details.
Rajesh Munshi April 11, 2022
Thank you for support Yamamoto I have one issue,
preform testing I have run full backup 2 time and I have checked in cloud storage is over the limit show how to clear,  any option, or wait 14-day auto-clear or contact Atlassian support
K. Yamamoto
April 11, 2022
@Rajesh Munshi The backup file doesn't occupy the storage capacity. It only counts up the attachment files. So please consider delete the unnecessary media files attached to issues and pages.
Rajesh Munshi April 12, 2022
Thank you Yamamoto , I took a backup of JIRA Software on April 6, 7, 10, 11
So I have to empty my storage, is there any way
Is there a way to delete a backup file?
David Lee April 12, 2022
Hi @K. Yamamoto
I set up the backup scheme from your post but after enabling whitelisting, i am no longer able to run either Jira or Confluence backups.   Any advice?
K. Yamamoto
April 14, 2022
@David Lee Good point. For those using IP Allowlistinginclude the IP ranges introduced at Outgoing Connections.
Ajay Goud Gaddam
Hi @K. Yamamoto ,
I created automation for automated backup with the above mentioned procedure in my Jira cloud,
Can you please help me here for what I am missing here.
Thanks in advance for your feedback,
varma
Richard Alleman May 29, 2022
Is there a way of performing a Confluence & Jira backup without burning a license? I don't want to use a personal account to generate an access token for backup and I don't want to burn a license on an account whose only purpose is to backup. What's the alternative?
Danny Grenzowski _Rewind_
Hi @Richard Alleman, my team at Rewind just launched a new automated backup and restore app for Jira Cloud, feel free to check it out here:
https://marketplace.atlassian.com/apps/1226389/rewind-backups
It doesn't require a separate Jira license - your backups are stored on a completely separate 3rd-party service (Rewind). We are also close to launching an identical product for Confluence Cloud too, in case you are interested. Let me know what you think!
Danny
Like Maria Korolenko likes this
Gregor Mitchell
I am having trouble getting to the Jira automation page.  When I try it wants me to sign up for a free account.  I have a premium account.  When you talk about scheduling the task you just go right in to it.  Is it possible to add how you get there?  I've never used the automation before.  I gather the other commenters found it without issues since they don't mention it.
Nijas Rawther November 16, 2022
@K. Yamamoto
Thanks for this article.
I am using the python script to automate the backups and they are working fine and generating the zip files.
Can you point me to the scripts to automate the restore workflow as well?
César Muñoz December 27, 2022
I'm following this procedure, even with 2 different accounts and 2 different Jira Software sites, but I always get the same error: a 404 error page showing "Oops, you've found a dead link.". It happens when trying to access the URL https://<my jira site>.atlassian.net/wiki/rest/obm/1.0/runbackup (for intance https://smartkaleagestion.atlassian.net/wiki/rest/obm/1.0/runbackup).
Is this procedure still working, or what could I be doing wrong? Thank you.
December 27, 2022
To help automate backups in real time and be able to get attachments, and issue back I would suggest to use Revyz.
Please if you get a chance check it out as its been life savor for our team.
