Automate online site-backups for Jira and Confluence without programming
71 comments
Gregor Mitchell
January 4, 2023 edited
@César Muñoz I've been trying to get a Linux script to work for this purpose but I have been successful with the powershell version. https://bitbucket.org/atlassianlabs/automatic-cloud-backup/src/master/backup-jira-api-token.ps1
It works.  It's just that it requires a windows server which I don't readily have.  I've run it from my windows 11 desktop successfully.
Like 4 people like this
Nicolás Guzmán
Thanks @K. Yamamoto for your efforts.
I'm also wondering if this implementation might work for automating Jira Cloud backups for Server?, I mean, to get a backup that I can restore in a Server instance.
Finally, since this backup doesn't include information in Jira Assets, is there any way we can generate one by Automations?
Like 2 people like this
Vish Reddy {Revyz}
January 25, 2023
Hi @Nicolás Guzmán
I don't believe a backup taken from the cloud can be restored back into a server instance.
Unfortunately I don't believe there is a solution for Automations backup at this point.
BTW - We are building support for Jira Assets both backup & granular restore in our Revyz backup as a service app. Happy to share more details if interested.
Maria Korolenko
For anyone looking for  "one tool backs up everything, I'd recommend Rewind. We backup Jira, Confluence and Bitbucket. GitHub as well if you're using it.
Jira Service Management and Jira Work Management are included in Jira backups.
 It's SOC2 compliant and users who are HIPAA compliant are using Rewind as well.
The Atlassian team recommends us as their third-party backups for Confluence.
Like 5 people like this
Krzysztof Przeor
May 9, 2023
Hi, I will run the powershell script
When I want to automate the download process through the task scheduler, the download hangs :/ The problem does not occur when the script is run manually. With the task scheduler it always hangs from when the copy exceeded 10gb, sometimes 500mb will be downloaded, sometimes 6gb and the file is corrupted. Anyone had this problem and know a solution?
Like 3 people like this
Dominik Spescha
Hi everyone
I'm trying to use the Backup script for Jira Cloud. I always get the error "{"message":"Client must be authenticated to access this resource.","status-code":401}" Does anyone know how to solve this? I also tried to modify the curl to use the API Token but still the same.
Like ashleytse likes this
Dominik Spescha
Gonchik Tsymzhitov
September 9, 2023
Nice job!
adithya
i have this issue when try to create automation. i fill the headers based on this article.
any idea how to fix it ?
adithya
i got Response412Precondition Failed when i try this automation.
Date: Mon, 16 Oct 2023 13:01:23 GMT
Content-Type: application/json;charset=UTF-8
Server: AtlassianEdge
Timing-Allow-Origin: *
X-Arequestid: 4dcc80c09590f25e75b01c40059d1e74
Set-Cookie: atlassian.xsrf.token=4254168488df260eeb94784904a3d937e984e26e_lin; Path=/; SameSite=None; Secure
X-Aaccountid: 6024c219f6e6c500690f1077
Cache-Control: no-cache, no-store, no-transform
X-Content-Type-Options: nosniff
X-Xss-Protection: 1; mode=block
Atl-Traceid: 904a6919255d3d46
Report-To: {"endpoints": [{"url": "https://dz8aopenkvv6s.cloudfront.net"}], "group": "endpoint-1", "include_subdomains": true, "max_age": 600}
Nel: {"failure_fraction": 0.001, "include_subdomains": true, "max_age": 600, "report_to": "endpoint-1"}
Strict-Transport-Security: max-age=63072000; includeSubDomains; preload
Transfer-Encoding: chunked
Nagabharana S
October 31, 2023 edited
Hi @K. Yamamoto ,
Just wanted to understand if the above shared steps to backup Jira cloud (auto) would track its activity in logs?
cc : @[deleted]
bhanu teja December 20, 2023
Hi @K. Yamamoto
we have a requirement In cloud to auto backup I tried the above steps in automation but throwing errorin automation can you please help on this
André Bonhôte anb
May 16, 2024
Is there an API documentation to figure out what all the /rest/backup/*-endpoints are doing? I spent a while this morning, to no avail ...
Jack Adams
Has anyone worked out a method to automate the exports of backups? I've managed to automate the creation of backups with this method but unsure and unable to find anything about actually exporting the backups automatically?
César Muñoz May 29, 2024 edited
Hi @Jack Adams
Atlassian provides scripts to do backup: https://bitbucket.org/atlassianlabs/automatic-cloud-backup/src/master/
You have to download and configure the script on your machine, and then schedule it, for instance with Windows task scheduler. Of course, you can't power off your machine when the backup is scheduled because it wouldn't be performed.
ELFAPP Technologies
June 3, 2024
For any administrator who needs an easy solution that integrates well into your Jira site to perform Jira Cloud backups and project exports of any size for all fields conveniently with all data residing within your Jira site. Please see these discussions
Where we explained how our app helps with such use cases.
Avikal Gupta
July 18, 2024
What is the URL of the documentation for JIRA Backup? How that get authenticated using OAuth?
Wael
September 3, 2024
The solution is a nice alternative to having to do the manual backup and get a regular automated backup done, wondering if there is a way to exclude -uncheck the box- for the attachments not to be included in the backup.
I've tried removing the cbAttachments or even setting it to "false" still, the backup runs with the attachments box checked.
If anyone has ran into this and has the solution, would be much appreciated sharing it with the community.
Thank you!
Slava Gefen
Hiya!
There is a mistake here:
  • Webhook URL{{baseUrl}}/wiki/rest/obm/1.0/runbackup
because {{baseUrl}} already gives /wiki at the end.
So, we have to use:
{{baseUrl}}/rest/obm/1.0/runbackup
With kind regards
Slava
Christian Schneider
October 8, 2024 edited
I am trying to write a script for triggering the Jira Backup Manager. I keep running into response 412 - no matter how long I wait for the next run of the script.
As Jira gives time limitations on how often you can run the web request, it is very difficult do develop a script.
Could you introduce a test-flag for the web request? -> While developing, I need the usual responses of the Rest-API without the need to create a real backup.
And any help on this one is very much appreciated: https://community.atlassian.com/t5/Jira-Service-Management/How-to-trigger-Jira-Backup-Manager-via-Powershell-gt-keep/qaq-p/2833811
Like Sonya McNeely likes this
JOSHUA H PATCH
November 4, 2024
i've gotten the automations to do *something* for both jira and wiki.  I've noticed the format of the wiki backup is different with the cloud automation vs. the manual verison
manual:
confluence_backup_csv_<date>.zip
  • attachments
    • files whos names resemble registry entries
  •  data
    • <something>.csv.gz
  •  whiteboards
    • data
      • whiteboard_export.csv
  •  metadata.json
automated:
Confluence_export.zip
  • attachment
    • numbered folders
      • files (no extension)
  • entities.xml
  • exportDescriptor.properties
    why are these different? are they both useable for cloud as backups? can confluence be restored from both types?
Register Now
