Automating the creation of a Confluence page linked to a Jira ticket
37 comments
MollyJo Tighe
@Esther Strom Just want to start off by saying that this tutorial really unlocked some huge time savings for me and the team. Incredibly highly appreciated, thank you for putting it together and how clear it was.
Question from a newbie - is it possible to do something similar to Edit a current Confluence document? In particular if I wanted to edit title, tags, or other more easily accessible content or populate variables from my original POST Confluence article creation.
Use case: I use a POST as described above to create Internal Release Notes when a version is created in Jira. I fill in relevant information using lookups, but over time that information may change and so it would be great to edit that same document later when the version releases.
Thank you again so much for this article plus all the time you've spent answering questions!
Mikey.Heather-Brash
March 2, 2023
Hi @Esther Strom I've set up an automation rule to generate a page on confluence every week along with the jira ticket using the automation provided. I've created a custom template and made it so that the title changes every week with the date to ensure no duplication. But I can't seem to figure out if there is a way to generate the link between the confluence page and the jira ticket using the automation. I was hoping you could help.
Carlos Gaona
June 14, 2023
Hello, team. Anyone knows if I can change the "key" (space) for any variable for application link? I need to connect to +200 projects and I want to know if there is something that I can use to connect this automatically to Jira project and confluence space connected by Application Link.
Saira
How do you retrieve the URL of the created page?
Melissa C
@Esther Strom
Hello Esther,
This post is very informative but I'm getting errors when I'm using the Webhook in Jira Automation,  I'm getting an 401 Error,
I've posted questions and now one seems to be get this to work.
Any other suggestions for struggling Jira/Confluence user?
fastcoder March 5, 2024
Just wanted to check
Can the edit confluence page when an issue gets edited be automated as well?
If so how do I proceed/ Thanks
Carlos Garcia Navarro
Great article! Thanks for sharing, Esther!
Jyoti Mane
How do you retrieve the URL or page id of created page ?
Esther Strom
FYI to all: this article was written before Confluence automation had been introduced. There's now an action available in Jira's automation that allows you to create a Confluence page; I would use that going forward.
2024-05-29 11_05_48-Rule builder - Automation - Kanban Adoption Template - Jira - Vivaldi.png
Like Patrick Cavins likes this
Melissa C
Hello
Has anyone gotten this to work?
What version of Jira is the "Create new content in a Confluence Space" option.
Jennifer Neusch
@Esther Strom - thank you SO much for the update! I was so glad that I scrolled to the 2nd page of comments to see it. It works great and I had completely missed seeing the Learn more about created page smart values!
Troy Anderson
Here is a recent example.  This one updates an existing Confluence page instead of creating a new one every time.  It is using a list of issues (any JQL) and populating them to the page.  https://community.atlassian.com/forums/Jira-questions/Re-Create-confluence-page-based-on-issues-set-to-specifi/qaq-p/3004982/comment-id/1120965#M1120965
