Automation for Jira - Send web request using Jira REST API
64 comments
Daniel Brvnistan April 8, 2024
When will this be available for the Data Center? It's unusable without it.
I believe Automation Rule project permission allow user to copy the Authorization header (JIRAAUTOSERVER-522) addresses this issue. I upvoted it.
vincenzo_spatafora
Hi @Cristiano
I have created a Jira automation rule for editing (PUT) in a specifc confluence page the value of a field (called in my case "% Completion").
But you get an error message saying:
Error publishing webhook. Response HTTP status: 401
Do you see a reason for that?
Thanks in advance, Vincenzo.
vincenzo_spatafora
Hi @Cristiano,
I use Jira DC version 9.12.5.
Thanks, Vincenzo.
Yash Sheetal Bhandarkar June 18, 2024
Hello Team,
I am trying to configure an automation in which I wanted to email the Assignee, Watchers & Reporter the list of issues through JQL regularly.
I have configured it.
Can you please help me with the custom field data to display through Lookup Issues?
Yash
June 18, 2024
Hi @Yash Sheetal Bhandarkar
I recommend creating a new question, helping to focus the conversation on the specific problem you are solving.  When you create the question, please include:
  • describe the problem you are trying to solve; that is, "why do this"
  • what version of Jira you are using, as that impacts the available automation features  (e.g., Jira Data Center's version of Lookup Issues does not support all fields yet)
  • what project type you are using, as that impacts the smart values / fields available
  • an image of your complete automation rule
  • images of any relevant actions, branches, conditions, and the trigger
  • an image of the audit log details showing the rule execution
  • describe what is not working as you expect
Those will provide context for the community to offer suggestions.  Thanks!
Like 2 people like this
Rosana Casilli
I have a question and if I want to do it in service management project?  does any of the parameters change?
using the info provided in this article I am getting a 404 form not found. I think it is because the api parameters refer to jira and not to jira service desk. isn't it?
Thanks in advance
Ro
Khira Niemeier
Hey there,
I am currently trying to find a solution to clone an issue with an automation and copying the Confluence Pages linked to the trigger issue to the new created issue.
I really try to understand how to use this documentation to make it work, but I can't tell how and where I could include this into the automation.
If it is possible, could somebody help me with this? :)
October 15, 2024
Hi @Khira Niemeier
I recommend creating a new question, perhaps including a link to this older article's thread, to ensure the maximum number of people see it to offer suggestions.  That will help focus the discussion on your specific scenario.
When you write your question, please include the following:
  • what problem are you trying to solve; that is, "why do this?"
  • what have you tried to solve this need
  • what version of Jira you are using: Cloud, Server, Data Center
  • what project type you are using: company-managed, team-managed, and if it is Work Management project
  • if you have a rule started and it does not work as expected, please include:
    • an image of the complete rule
    • explain what is not working as expected, and how you know that
Like Khira Niemeier likes this
Khira Niemeier
Hey,
I really tried to understand this but I need help.
So I understood that I need to create an API token. (I did.)
And I encoded it with Base64.
Now what do I do with it?
I have this Automation:
The Automation throws the error:
So I guess the thing with me not having the permission is due to the API token not being inserted anywhere. With the error I have no clue, if it is due to the API token.
Please send help. :)
October 23, 2024
@Khira Niemeier -- Please review the article where is shows entering the Header information for the request.
Khira Niemeier
In case somebody got stuck at the same point - here is how to go on. ;)
You need to fill the header with
key = "Authorization"
value = "Basic <the encoded <Mail>:<APIToken> >
To get it encoded just make sure you write <your mail>:<APIToken> into the encoder.
In case you need a different Response then 200, you might want to use {{webResponse.body}} (which is what I need most likely)
or {{webResponses}} which gives out more information.
Like Patrick McGuirk likes this
Florian Wehner
This is wonderful! Thank you!
Clarisse Dalina
March 18, 2025
@Cristiano , alot has changed since the 2020 version in this article, is there a latest article about this? Thanks!
Like 3 people like this
Joe Zaynor September 11, 2025
Thanks so much for this article!
I've been struggling with authentication for several days and couldn't figure out what the problem was.  This article is the only thing I've seen that says to leave off the line break at the end!  I left off the last character in the encoded token, an equal sign, and got a 200 response for the first time!
Upcoming Jira Events
