CVE-2019-11581 Critical Security Advisory for Jira Server and Data Center - Template injection
Atlassian has published security advisory CVE-2019-11581 today, 10 July 2019.  This advisory is in regards to multiple versions of Jira Server and Data Center.  Jira Cloud is not affected.  The goal of this article is to help raise awareness for this critical vulnerability and to provide you a means to ask further questions about this in Community if needed.
Atlassian's official recommendation is that all affected Jira instances upgrade to a fixed version as soon as possible.
If you do nothing else, turn off the Contact Administrator's form immediately in Jira.  While Jira ships by default with this feature OFF, you can check to make sure it is disabled if you are a Jira administrator by going to
  1. Choose  > System
  2. Select General Configuration to open the Administration page.
  3. Click the Edit Settings button
  4. Scroll down to the Contact Administrators Form and select OFF
  5. Scroll to the bottom of the page and click the Update button for this setting to take affect.
More details on this option in Configuring Jira application options - Atlassian Documentation
If this option is enabled, and Jira is setup to use an SMTP mail server, it is possible that one avenue of this vulnerability could be exploited by an unauthenticated user in Jira.   There are additional mitigation steps below, but these apply to authenticated users that require Jira administrator permission levels to exploit.
Affected versions:
  • 4.4.x
  • 5.x.x
  • 6.x.x
  • 7.0.x
  • 7.1.x
  • 7.2.x
  • 7.3.x
  • 7.4.x
  • 7.5.x
  • 7.6.x before 7.6.14 (the fixed version for 7.6.x)
  • 7.7.x
  • 7.8.x
  • 7.9.x
  • 7.10.x
  • 7.11.x
  • 7.12.x
  • 7.13.x before 7.13.5 (the fixed version for 7.13.x)
  • 8.0.x before 8.0.3 (the fixed version for 8.0.x)
  • 8.1.x before 8.1.2 (the fixed version for 8.1.x)
  • 8.2.x before 8.2.3 (the fixed version for 8.2.x)
Fixed Jira Server & Jira Data Center Versions:
  • 7.6.14
  • 7.13.5
  • 8.0.3
  • 8.1.2
  • 8.2.3
Mitigation
If you are unable to upgrade Jira immediately, then as a temporary workaround, you can:
  1. Disable the Contact Administrators Form; and
  2. Block these endpoints from being accessed:
    /secure/admin/SendBulkMail!default.jspa ,
    /admin/SendBulkMail!default.jspa , and
    Note that blocking the SendBulkMail endpoint will prevent Jira Administrators from being able to send bulk emails to users.
    This can be achieved by denying access in the reverse-proxy, load balancer, or Tomcat directly (see the KB: How to block access to a specific URL at Tomcat).
After upgrading Jira to a fixed version, you can re-enable the Administrator Contact Form, and unblock the SendBulkMail endpoints.
Additional information
0 comments
Community moderators have prevented the ability to post new comments.
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
