Create and save multiple board views in business projects
Hi Jira Community,
As part of the rollout of the new navigation, we’ve released the ability to add multiple board views (maximum of 5), to your business projects. Additionally, you’ll be able to tailor each board to your teams needs by applying view settings and saving them for everyone.
What to expect
We'll begin progressively rolling out these updates from March 2025, alongside the new navigation.
The key changes to look out for are:
  • Project administrators will be able to create multiple board views in a business project.
  • Project administrators will now have the ability to save the following board view settings for all users of the project:
    • filters applied
    • group by configuration
    • board card fields
    • selected workflow
    • column order
    • column collapsed/expanded state.
  • Everyone with access to the project will have the ability to revert the board view to the last saved state.
  • Project admins can rename all tabs (navigation items) in the project navigation in business and software projects. Project admins and board owners can rename the tabs in the board navigation.
Got feedback?
We’d love to hear your thoughts - drop your feedback and let us know what you think!
Thanks for being part of our community! red heart
19 comments
__ Jimi Wikman
I did not know that Jira Work Management was still available? Is this just for those that had it before the merge, or is this some kind of project type you can actually create?
Like Amanda Barber likes this
John Funk
@__ Jimi Wikman  Jira Work Management is now just referred to as Jira - but there are two project types: Business - the formerly known as Jira Work Management; and Software - more or less formerly known as Jira Software.
Like # people like this
John Funk
@Yuan Jiang  - This is great news and has been needed for a long time. So if I am understanding correctly, an Admin (Jira or Project) can set a standard and save it based on filters selected, column order, etc. But the user will still be able to change things to modify those saved items for what they want to see. This will be maintained for them when they come back into the board each time. But if they want to go back to the standard Admin saved version, they will be able to do that.
Is that the case? Is there anything I am misunderstanding?
chris sieverts
This is very interesting @Yuan Jiang . Is there any plan to extend this to company-managed projects? Thank you
Yuan Jiang
March 26, 2025
@John Funk Yes your understanding is correct. To be more specific, non-admin individual user can use the "revert" button to go back to the project-level view set by their admin at any point of time. The "revert" button also serve as a signal to individual user, if they don't remember if they're looking at an individual only view or project level view
@chris sieverts This feature is available for the board view in both Team-managed and company-managed business projects. Long term, we plan to bring these to all project types (software and business, team-managed and company-managed). We will likely do this view type by view type. Is there any particular view you're super keen for?
chris sieverts
Hi @Yuan Jiang I was not aware that it was available so thank you.
__ Jimi Wikman
@Yuan Jiang @John Funk That is interesting, and how would you go about to create a Jira project that is a business project? I see nothing in my instances that have that distinction and if they have a different code base, that is very important to understand when you create what type and what the impact of that would be?
__ Jimi Wikman
Ok, I see it now. The template will actually decide which configuration base your project will have... Do we have a list of these so we know what project will give a Business configuration (Work Management) and which will give a Software configuration?
Jens Schumacher
March 30, 2025
@John Funk
I believe the core difference is still company-managed vs team-managed. Albeit, it's rather confusing that there are now Software and Business projects as well.
@Yuan Jiang
What's the rationale behind creating even more project types? Understanding the difference between company and team managed is already a challenge. With Software and Business projects added to the mix, that confusion is multiplied. Shouldn't these just be different templates?
John Funk
Business projects were around before everything else - that is what Jira Core was. Then came Jira Software projects. Then JSM. The above were always company-managed in operation. Then came team-managed and everything fell apart  hahaha.
Audrey Turner
April 3, 2025
This is great!  When is the change coming?
Sylvain - Jira - Eng
April 10, 2025
Hi @Audrey Turner
The change is being rolled out to customers over the coming weeks so you should be able to see it soon.
Cheers!
Calvin Hulse
April 17, 2025
@Sylvain - Jira - Eng
Any way for users to know/estimate which batch of rollouts they'll be included in? If not, are you able to share a deadline by which rollouts will be completed for everybody?
This is a great set of features and my team is eager to implement
Calvin
May 14, 2025
Hi @Calvin Hulse and welcome. This functionality is only available for customers who have received the new Jira navigation which is still rolling out. Should be completed around July. You may be able to reach out to support if you want your site to receive it earlier.
Cheers!
Sherry Nightingale
It mentions what a Project Administrator can do on a board but then says as a user they can revert it back to what it was before - is that correct?
May 16, 2025
Hi @Sherry Nightingale, let me try to clarify. Normal users are only able revert their own configuration changes back to what a project admin has saved for everyone. Essentially, a project admin can save the configuration of a board view as as base/default for everyone and then users can apply their own changes on top that they can also revert to go back to the base state.
Hope it helps.
Monika Rani
@Yuan Jiang This feature is a total game changer—I’m loving it and using it often!
May 19, 2025
Thank you @Monika Rani that's great to hear! We are working on bringing this functionality to other views as well.
Monika Rani
@Sylvain - Jira - Eng, It would be great, I am waiting.
