Creating subtasks within epics in the work item panel
Hello Jira Community,
We're making an important update to how subtasks are created within epics.
In work item view, you can no longer create subtasks within epics via the subtask panel. Instead, all existing subtasks will be merged into the work item panel, alongside other child work items. New work items can still be created, but only one level down in the hierarchy.
Why are we making this change?
This change aligns with Jira’s work hierarchy and resolves exisiting inconsistencies. Creating subtasks within epics and initiatives has led to:
  • Bad hierarchy data – Causing compatibility problems with other products and features.
  • Confusing user experience – Some users expect to create subtasks under epics/initiatives, but can’t unless the subtasks panel is already available.
  • Experience limitations – We want to streamline work structures and make sure subtasks only exist under base-level work items.
What do you need to do?
Nothing. If you have existing subtasks under an epic we’ll merge the tables.
If you need to track smaller tasks within an epic, here’s a couple of options:
  • Create work items one level down – You can still create stories, tasks, or bugs under epics.
  • Use “Action items” – If you want to track small tasks within an epic, use the “Action item” feature by selecting the checkbox in the editor or typing /action item.
Thank you,
Ahmud
Jira PM-Work Item Experience
17 comments
Tomislav Tobijas
Hi @Ahmud Auleear ,
It's been a while since you couldn't create Sub-tasks directly under Epics. But, you could do so within upper levels of the hierarchy (e.g. level 2 or 3).
Does this change mean that you won't be able to create Sub-tasks under levels 2 and 3 anymore? 👀
We're just exploring one solution which uses this approach so I'm asking as we'll need to move away from that solution option then.
Tobi
Dave Mathijs
Hi @Ahmud Auleear Logical decision, respect the work item hierarchy and keep it standardized.
Like Martin Runge likes this
Ahmud Auleear
March 31, 2025
Hey @Tomislav Tobijas
In Jira, we are moving towards the direction that you can create child issues only one level down from a parent issue. For example this could look like:
  1. Epics: The highest level, representing large bodies of work.
  2. Standard Issue Types (e.g., Stories, Tasks, Bugs): These are the immediate children of Epics.
  3. Sub-tasks: These can be created under standard issue types but not under Epics.
Like # people like this
Tomislav Tobijas
Hi @Ahmud Auleear ,
Yeah, I get that. But, let's move away from Epics for the moment and look at the upper hierarchy levels; e.g. example below:
Currently, you can create Sub-tasks below Deliverables, Initiatives and Themes. With this update, I'm guessing that won't be possible as well.
I'm definitely up for it > to have a cleaner and more consistent hierarchy together with better data reports, I'm just asking as it's been a while since you couldn't create Sub-tasks under Epics (at least not directly) so I'm guessing this update will do the same just for upper levels.
Tobi
Ahmud Auleear
June 10, 2025
Hey @Tomislav
Yep, that's right.
With the changes we're rolling out, sub-tasks will only be allowed one level down from a standard parent issue. That means you won’t be able to create sub-tasks under Deliverables, Initiatives, or Themes either.This is in line with the goal of enforcing a clean, logical hierarchy:
Parent → Child → Sub-task, with no skipping or nesting across multiple levels.
Like Tomislav Tobijas likes this
Ahmud Auleear
June 10, 2025
Hey,
We’re beginning to roll out this change starting today, and expect to have it fully deployed by the end of the month.
Ahmud
Tomislav Tobijas
@Ahmud Auleear got it. Thanks for the update!
Terriann Nohilly
June 20, 2025
hi hi, this is sadly caused a big problem for the way in which we were planning to track work. Is it possible to get this feature rolled back for our account?
Ana Carolina Giampietro Martins
June 24, 2025
Hi @Ahmud Auleear
I would like to know if there is a defined cutoff date for this change to be official?
At the company where I work, we rely on automations that create subtasks within epics, which are essential for generating key reports using the EazyBI tool.
Have these automations also been affected by the change? If so, could you please clarify when they stopped functioning?
Best regards,
Ana.
Like Karine VANEL likes this
Vinícius Soares Fonseca
June 24, 2025
Hello @Ahmud Auleear
Any chance you could roll this change back for our account or at least give us the option to turn it back on? Not having it impacts how we currently track work. The two structures have different meanings for us, and we rely on both to manage and organize our tasks.
Best regards
Terriann Nohilly
June 24, 2025
me too me too!! I want it rolled back too! (I work at Procore)
Dr_ Johannes Dagner
July 11, 2025
Hello @Ahmud Auleear ,
for our workflows this is not a cool move. It messed up some hundred work items. I though jira should make our work more efficient - this the opposite. We also would like do roll back.
Kind Regards,
Johannes
Ahmud Auleear
July 16, 2025
Hi everyone,
Thanks for all the feedback.
Unfortunately, we're unable to offer rollbacks for this update. This change is part of a broader effort to align Jira’s issue hierarchy across all experiences and improve long-term data consistency and feature compatibility.
That said, we absolutely want to help you adapt as smoothly as possible. Here are a couple of options you can consider:
  • Use Action Items: For lightweight tracking of smaller tasks within an epic, you can use the “Action item” feature by typing /action item or selecting the checkbox in the editor.
  • Break down epics with standard issue types: Instead of using subtasks within epics, create Tasks or Stories under the epic. Then use subtasks within those stories/tasks as needed. This keeps your hierarchy clean:
    Epic → Story/Task → Sub-task
Sam Hammond
@Ahmud Auleear As per you last comment Epic → Story/Task → Sub-task is also not working for me since you roll-out this big change. It disrupted how we were managing the issues in our organization. We were previously creating sub-tasks under stories but now we are unable to do so. So i created an epic and tried to add a story under that but i am also not able to add story under and epic either now. Like i just want to add a sub-task under a story as story being the parent. But i am unable to do so now. Attaching my workflow hierarchy. Please tell me what to do and it's really urgent and important for me being a Scrum master and Project Lead my work is affected by this change.
You can see in the photos that i am unable to link my story to my epic or my sub-task to my story.1.png2.png3.png
Sam Hammond
@Ahmud Auleear Is anyone here I am waiting for response?
Vesa Purho
If  one solution is to use action items, are there any plans to support action item markup in Jira Automation? Now the way to create action items through automation is possible, but a bit cumbersome: Introducing Action items in Jira - Atlassian Community
Robert Horn August 27, 2025
one major down side is that the work item pannel doesn't provide the functionality to manually order its item and keep that order.
that was possible for the sub-tasks.
I really do hope that you are working on this i feel is a base functionality that should be availble for related items to any work item ... an Epic hold work items to be completed in a specific order but this order is something that is being discovered in the course of addressing the Epic .... so please bring this back
