Customizing card covers in your Jira boards can enhance visual organization and help your team quickly identify issue types or priorities at a glance.
For more detailed information, you can also refer to the official Atlassian documentation on Customizing Cards in Jira.
To personalize individual issue cards on your board, follow these steps:
Hover Over an Issue: Navigate to the board and find the issue you want to customize. Simply hover your cursor over the issue to reveal more options.
Select More Options: Click on the ••• (more) icon that appears on the issue. This will open a dropdown menu with additional actions you can perform.
Edit Cover: From the dropdown, select Edit cover. This option allows you to modify how the card appears on the board.
Choose a Color or Upload an Image: You will have the option to either:
Your issue's card cover will now reflect the changes, making it easier for team members to recognize important information at a glance.
Cristian0791
Senior IT Engineer
Bucharest
51 accepted answers
6 comments
