@Bill Sheboy this just in - Atlassian Decoder Ring will now be renamed Translation Table to be more accessible to teams of all types. :-P
Jokes aside, I like the change assuming that Atlassian preserves our JQL, automation rules, etc. and does provide some sort of way to easily understand the before and after terminology.
Is there a summary of all the name changes going on somewhere?
Jira Issues > Work Items
Products > Apps
Plug-Ins/Apps/Add-Ons > ?
Projects > Spaces
Any others that I'm missing?
And when do all of these changes start impacting our end users? As some others mentioned, when will the projects terminology in JQL change over to spaces?
This is a significant shift, and it's great to see Atlassian working to create a more unified and intuitive experience across products. That said, since "spaces" already have a strong association with Confluence, I’m curious how this change will impact user training and cross-product understanding.
Will there be clear visual labels to help users differentiate between Jira "Spaces" and Confluence "Spaces"? Looking forward to seeing how this evolves!
For the record, I like this change, as I've had customers refer to Jira projects as Jira spaces (at multiple companies, with no rhyme or reason).
If such a change makes spaces a literal space for work (items) and pages, this should reduce the cognitive load for our users. And since there are usually more users than admins, I support this change. 😉
I honestly don't care how much re-work this is going to cost me in updating automations, filters, dashboards, and documentation if it means I don't need to explain the difference between Project and Project yet another time!
June 24, 2025 edited
Thank you for your feedback and comments on the proposed changes. I would like to address the most frequently asked questions regarding JQLs, APIs, and automation rules here:
- APIs will continue to function as they currently do. - JQLs will support the new terminology alongside the old one, so they will remain operational. - Automation rules will not require any updates either.
Watch this space for further updates and information about this change. If you have any further questions, feel free to reach out!
Awesome!!! Much needed clarity and alignment for those of us that are fairly new to Atlassian world and are using the suite of tools for everything in a department, not just a development team. Now if we could get the concept of a 'parent sprint' ;)
Great move! It seems that "spaces" bring a more flexible or collaborative feel to Jira. It might match better with the way cross-functional teams structure their work
This is a much-needed update—I’ve been waiting for it for a long time. It was always difficult to explain the difference between a Jira project and an Atlassian project, as many people were confused by these two terms. With this change, things are clearer.
However, I think the introduction of Jira Space and Confluence Space might still cause some confusion for users, especially new ones. Clear documentation and onboarding guidance will be essential.
As an Atlassian Champion- I have created this video https://youtu.be/JX8qzWYZ5zk so that people (specially my viewers/subscribers) can know about this update.
The next thing on the list for a rename should be Epics in Jira... thoughts anyone?
Wow!
Could you elaborate a bit more on that? What exactly bothers you about the term Epic?
In my opinion, Epics and Stories are well-established terms that represent Agile like no others. They’re widely understood and have become a kind of common language. If you need "Initiative" or "Programm" instead or above, that is possible as you may know...
@roydbrayshay you can rename them today if you like as the changes to Epics have been rolled out. I always rename them to Features ;)
@David Friedrich The term in itself is not a problem, the fact that it is used on multiple levels are. If you use the term Epic, then you are just saying a large thing, since Epic is not a defined object. So you have product Epics, Strategic Epics, Project Epics, Portfolio Epics....and so on.
The most common issue I face a lot is when people set up planning boards that they call Epic boards. Those Epics are very big, so when you then break them down, you will have features on Story levels and the actual work in sub-tasks. That causes problems since you are now blocking the developer to break down their work and all activities will be out of sync with other teams that uses Epics as feature and then stories as the work item.
Add a few dimensions to that and when you have programs breaking down projects as Epics, or large deliveries over multiple projects as Epics... Yeah, that is why we have work item hierarchies, but since many work in silos and down know how the rest of the organization works, this can get messy fast.
48 comments
