Recently, I faced to interesting and challenging task.
We are moving one huge Jira instance to unified Access Management, which will be driven by user request in dedicated project and approved / declined request will automatically add users to users groups, which are shared in Permission Scheme through more projects.
Well, this part will be covered in another article, but as a predisposition, I had to migrate all of the users from Projects Roles to User Groups.
Doing this manually would take hours, maybe days with possibility of making a lot of mistakes.
So I took inspiration @JamieA answer over there https://community.atlassian.com/t5/Answers-Developer-Questions/How-to-list-all-members-of-a-certain-project-role/qaq-p/528122 and created a script for that.
As sharing is caring, I would like to share this with everyone, because I find this quite useful :-)
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.atlassian.jira.bc.project.component.ProjectComponentManager
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.security.roles.ProjectRoleManager
ProjectRoleManager projectRoleManager = ComponentAccessor.getOSGiComponentInstanceOfType(ProjectRoleManager.class) as ProjectRoleManager
def projectComponentManager = ComponentAccessor.getComponent(ProjectComponentManager)
def projectManager = ComponentAccessor.getComponent(ProjectManager)
def groupManager = ComponentAccessor.getGroupManager()
def usersKeyString
def usersObjList = []
ProjectRole devsRole = projectRoleManager.getProjectRole("Developers") //SOURCE: Change to appropriate Project Role
def group = groupManager.getGroup("group_developers") //TARGET: Change to appropriate Jira Group
def Projects = projectManager.getProjectObjByKey("FOO") //PROJECT: Change to Project you are working with
for (item in Projects)
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(devsRole, item)
usersKeyString = ("${actors.getUsers()*.key}").toString()
usersKeyString = usersKeyString.replace("[","")
usersKeyString = usersKeyString.replace("]","")
usersKeyString = usersKeyString.replace(" ","")
def usersKeyList = usersKeyString.split(',').collect {it as String}
for (item in usersKeyList)
def userObject = ComponentAccessor.getUserUtil().getUserByKey(item)
if (userObject != null)
usersObjList.add(userObject)
for (item in usersObjList)
groupManager.addUserToGroup(item,group)
I also refactored original @JamieA answer, as It contain deprecated Component Manager and few not anymore available method. (Unfortunately original thread is locked, so I cannot post answer over there).
So here is the script compatible with Jira 8.x version which will generate list of specified Project role in all projects:
Key | Name | Lead | Member
def actorsList = []
def instanceList = []
ProjectRole devsRole = projectRoleManager.getProjectRole("Developers") //Specify the project role you would like to list across the Jira
def Projects = projectManager.getProjectObjects()
instanceList.add("$item.key, $item.name, $item.lead, ${actors.getUsers()*.name}\n")
return instanceList
Tomáš Vrabec
Atlassian Solution Architect & Consultant
Freelancer
Czechia
5 accepted answers
4 comments
