How to create Jira issues from Excel file?
40 comments
Bogdan Gorka
July 7, 2021
@serkan_sezer importing Importing cascading choice custom fields is described in the documentation https://confluence.atlassian.com/adminjiraserver073/importing-data-from-csv-861253680.html#ImportingDatafromCSV-PreparingyourCSVfile
Multi level cascading is not yet supported. See JRASERVER-34202
Michael Werner July 7, 2021
Thank you. Now I need my admin to get me access to it.
Tiago S_ September 1, 2021 edited
Thanks for the article, it's very helpful.
I'd like to ask a question: Is there any line break character that is recognizable by Jira?
I added characters like \n and \r , to organize the items in a list for the task description.
I wrote in the .csv file:
Task objective \n # Step 1 \n # Step 2 \n # Step 3 \n
Expecting as result:
Task objective
1. Step 1
2. Step 2
3. Step 3
Then I got:
Thanks in advance,
Tiago
Bogdan Gorka
September 2, 2021
Hello @Tiago S_
Like Tiago S_ likes this
Tiago S_ September 2, 2021
Hey @Bogdan Gorka
Thank you!
thinkcerti
September 21, 2021
Can I create Feature, related Epics and related User stories using a single CSV file? If yes, is there a dependency on the order of the entries in the csv file i.e Feature is first, Epic next and so on
Carlos Garcia Navarro
October 7, 2021
Nice article! Thanks for sharing! :-)
dD
Hey this is great! but can we go one step further and instead of importing the csv manually, can the system import it, when we send the csv-data per email? Is that possible? Thanks.
Ron Healy
April 12, 2022
For anyone who stumbles across this excellent article and wants to create an Excel tool to make capturing and then importing User stories easy, have a look at this blog post (for Jira or any similar platform):
"Tool to auto-generate User Stories with minimal typing and even less repetition"
Deleted user October 5, 2022
Am I right in understanding that only admins can do this? As part of a large organisation I would spend longer trying to find the system owner, get approval, explain the process, etc. than just manually adding a long list of sub tasks
Bogdan Gorka
October 6, 2022
@[deleted] yes, this functionality is available only for admins.
However, if your Jira instance is big, there will also be some governance around it to collaborate with users on enhanceement and data migration.
If you know how to prepare your migration file in CSV, there usually will be someone workin via Service Desk (or some similar tool) to take your request and import the data for you.
Alternatively, there is also a manual way available in menu Issues (DC version). This is available to 'regular' users, but it has some limitations.
Remya Ramakrishnan March 13, 2023
That was super helpful ! Kudos to your efforts in finding out and sharing with us :)
Remya Ramakrishnan March 13, 2023 edited
Can we import further details as well? like Original estimates, Start Date, Due date  ?
yuliya Nayton
August 19, 2024
Hi @Bogdan Gorka , we use Jira cloud and my understanding is one requires Admin access for the instance (not at a project level) to be able to do imports as described in this article. Is there a way to import tasks from CSV file into Jira with the project admin permissions and how to achieve this? Thanks
abhishek_madhu January 29, 2025
Seems like these options aren't available anymore in the places where it is shown. THe interface has changed.
