Sign up Log in
How to create a dashboard to identify projects at Risk?
Want to create a dashboard that easily allows you to report on project health? The above example uses a simple select list custom field, a custom issue type called "Project" to track projects, and an Issue Statistics gadget to create a dashboard that identified projects (issues of type project) at risk and off-track.
Follow the guide to configure the custom fields.
  1. Go to System Administration - Issues - Custom Fields.
  2. Create a new Custom Field of type Select List called "How are we tracking?"
  3. Add the following options for the select list.
    • <span class='aui-lozenge aui-lozenge-success'>On Track</span>
    • <span class='aui-lozenge aui-lozenge-current'>At Risk</span>
    • <span class='aui-lozenge aui-lozenge-error'>Off Track</span>
  4. Add the custom field to the appropriate screens on the issue.
End users can now update the issue status using the above custom field.
To create a dashboard,
  1. Create a new dashboard and add the "Issue Statistics" gadget. You can also add the gadget to an existing dashboard.
  2. Select the statistic type to "How are we tracking?" custom field.
Hope that helps.
For some other tips and tricks on dashboards and wallboards, refer to the articles below.
https://www.atlassian.com/blog/jira-software/7-steps-to-a-beautiful-and-useful-agile-dashboard
https://www.atlassian.com/blog/jira-software/3-steps-to-a-rocking-agile-wallboard
8 comments
Yogesh Mude
June 11, 2018
ohh.. it's pretty useful and understandable...
laralg
June 27, 2018
I am just going to leave a comment here to remind myself to check this out later. Thanks!
Like Jonathan Santos likes this
jorgefelix.siverio
December 9, 2021
When adding the options above, they show exactly how they are written when a user selects the dropdown. It does not show On Track, At Risk...etc.
Nallusamy Narayanaswamy
Yes, It shows as HTML span element as shown below
Bhushan Nagaraj
December 19, 2021
Hey Community,
Great to see people are still interested in this page. This page is now 3 years old and needs an update.
Luckily, there is a purpose built app by Atlassian that addresses this specific need of better project status communication. I encourage you to evaluate and explore Team Central by Atlassian. A product that is now in Beta. Keen to hear what you think and how your companies adopt it.
https://www.atlassian.com/software/team-central
Bhushan
Allie Stewart
I'm attempting to do this as well on Cloud and I get the same result as Nallusamy.
My select list options show as
Those actual texts.  Not lozenges to choose from.
Can someone advise?  Thank you.
Bhushan Nagaraj
June 6, 2023
@Allie Stewart you cannot do this on Cloud as it includes custom styling components. But we at Atlassian have launched a complete product to help with this very use case. Take a look at Atlas
https://www.atlassian.com/software/atlas
Like Cricket Williams likes this
Elizabeth Jones
September 29, 2023
I have implemented this in my instance and have found it to be incredibly useful; thanks!
Like Bhushan Nagaraj likes this
