How to export all issues from Jira via API
51 comments
Prince Nyeche
April 5, 2023
It's for the next release version.
Madhav Dube April 10, 2023
Also, @Prince Nyeche I am seeing many duplicated fields. Not sure if it is because of REST API endpoint. One such duplicated field in the export is `comment` like I am seeing 10+ comment fields in the export. Is it expected?
Prince Nyeche
April 10, 2023
In the export, those fields are expected to be in multiple columns as each column will denote a different value for such field. E.g. fields such as attachments, comments, labels, components etc will likely be in multiple columns.
Prince Nyeche
May 30, 2023 edited
Hey folks,
I have updated this function to include other arguments with the latest v0.7.6. So it is now possible to export issues into JSON format and the CSV export now allows you to select certain fields to be included before export using the include_fields argument. In the final export, only those fields mentioned will show up in the result CSV file e.g.
# previous expression
fields = ["Summary", "Assignee", "Reporter", "Labels"]
issue_export(jql=jql, include_fields=fields)
If you want to include the current field shown in your advanced issue search via the UI, you can use the field_type argument to achieve that. This will export a CSV file using only the default fields as configured via the UI
issue_export(jql=jql, field_type="current")
For import of attachments via CSV which demands the addition of your credential to the attachment columns, it is possible to use this same method to append a user credential which is acceptable by the Jira external importer.
issue_export(jql=jql, allow_media=True)
Then making it easier, to just import the projects and their media content.
If you have other Jira or even non-Jira CSV files and you want to merge all those files into a single file, you can use the merge_files argument which accepts a list of file names.
files = ["file1.csv", "file2.csv", "file3.csv", "file4.csv"]
issue_export(merge_files=files)
If the files you're merging are non-Jira files, you can use the check_auth argument to prevent the method from checking for authentication.
issue_export(merge_files=files, check_auth=False)
jorizdg
August 9, 2023
@Prince Nyeche Thanks for this. I get the following errors when I use the simple execution:
Exception in thread Thread-1:
Traceback (most recent call last):
File "C:\Users\jdeguzman\AppData\Local\Programs\Python\Python39\lib\threading.py", line 980, in _bootstrap_inner
self.run()
File "C:\Users\jdeguzman\AppData\Local\Programs\Python\Python39\lib\threading.py", line 917, in run
self._target(*self._args, **self._kwargs)
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\venv\lib\site-packages\jiraone\reporting.py", line 2415, in map_field
mapper = field.get_field(fname)
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\venv\lib\site-packages\jiraone\access.py", line 3606, in get_field
"key": a["key"],
KeyError: 'key'
Exception in thread Thread-4:
self.run()
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\venv\lib\site-packages\jiraone\access.py", line 3598, in get_field
"key": a["key"],
KeyError: 'key'
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\main.py", line 28, in <module>
issue_export(jql=jql)
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\venv\lib\site-packages\jiraone\reporting.py", line 2454, in export_issues
field_value_check(_field_names_) # We'll always check this
File "C:\Users\jdeguzman\PycharmProjects\Jira Export\venv\lib\site-packages\jiraone\reporting.py", line 2439, in field_value_check
raise JiraOneErrors(
jiraone.exceptions.JiraOneErrors: <JiraOneError: Unable to find initial field, probably such field "Sprint,Watchers,Reporter,Assignee" doesn't exist for fields argument>
I get the same error when I specify fields. Appreciate any guidance here. Thanks
Prince Nyeche
August 9, 2023
Hey @jorizdg
Change the fields argument to an empty list
fields = []
jql = ...
issue_export(jql=jql, fields=fields)
I believe this issue occurs on the Jira Server/DC. If you're using that then you might want to do
fields = []
jql = ...
LOGIN.api = False
Let me know which one works for you.
jorizdg
August 9, 2023
@Prince Nyeche  Changing the argument to an empty list solved it. (I'm on Jira DC so I used the latter option). Thanks!
jaych
January 10, 2024
@Prince Nyeche this API has been great to use in python but I'm trying to integrate it with Microsoft Fabric. The notebook runs alone but one I try to automate the process I get an error saying "Error: Size of notebook content and exit value must be less than 8MB. Please try to write large outputs to files"
Is there a way to change where the files are being saved to? I want to save the files to a data lakehouse in fabric. Thanks in advance.
Prince Nyeche
January 10, 2024
Hey @jaych if you are connected to any storage plugin within MS Fabric such as onelake, you can add a directory path or URI by using the folder argument and set a file name by using the final_file argument (optional). For example
issue_export(folder="<storage_path_URI_here>", final_file="<file_name>")
The concept here is that the folder argument expects a path-like object and it will attempt to link it to the filename before giving an output. As long as the path exists, it will generate and form a symlink to that path. Thereby allowing you to store the data in a different location other than the default which seems to be problematic in your notebook.
jaych
January 12, 2024
Thank you! That solved an issue I've had for months. I'm also getting a few errors after the report is complete.
1)DtypeWarning: Columns have mixed types. Specify dtype option on import or set low_memory=False.
2)FutureWarning: The default value of regex will change from True to False in a future version. In addition, single character regular expressions will *not* be treated as literal strings when regex=True.
3)FutureWarning: The default value of regex will change from True to False in a future version. In addition, single character regular expressions will *not* be treated as literal strings when regex=True.
Are these errors I can correct on my end or does the API have to be updated?
Thanks in advance.
Prince Nyeche
January 13, 2024
I believe those warnings are from the notebook API being used. Probably there's a configuration within the application settings to turn warnings off but I'm unsure about that.
Like jaych likes this
Birgit Saalfeld March 28, 2024 edited
Hello @Prince Nyeche
I need help with the following error message, since I don't have a clue, what I did wrong:
from jiraone import LOGIN, issue_export, USER
import json
file = "config.json"
config = json.load(open(file))
LOGIN(**config)
jql = "project=ITS"
Cell In[16], line 1
File ~\AppData\Local\anaconda3\lib\site-packages\jiraone\reporting.py:3365 in export_issues
File ~\AppData\Local\anaconda3\lib\site-packages\jiraone\reporting.py:3347 in field_value_check
JiraOneErrors: <JiraOneError: Unable to find initial field, probably such field "Watchers,Reporter,Assignee" doesn't exist for fields argument>
I am sure, that my authentication works, since print(LOGIN.get(endpoint.myself())) shows me 200 as response and I could successfully download all users (USER.get_all_users(file="user.csv", folder="USERS")). Furthermore, I also tried using the optional parameter "fields". Both: as empty element ([]) and with the columns you suggested earlier in the comments.
Setup: Access to Jira cloud with python 3.10.9 and jiraone 0.8.2 in Spyder, Anaconda.
Does anyone have any idea what I have to change to make the issue export call working?
Thanks a lot in advance!
### UPDATE ###
Since I am a python beginner, I oversaw that there is a difference between the function export_issue and the static function issue_export.
fields=[] # works fine
fields = ["key", "reporter", "issuetype", "status", "created"] # gives an error
export_file = "example_export.csv"
jql = "project=ITS"
issue_export(jql=jql,include_fields = fields, final_file=export_file, extension="csv", encoding="utf_8", delimit=";")
When I try to specify the columns, I end up with the following error:
Cell In[100], line 1
File ~\AppData\Local\anaconda3\lib\site-packages\jiraone\reporting.py:3370 in export_issues
field_value_check(
JiraOneErrors: <JiraOneError: Unable to find initial field, probably such field "key,reporter,issuetype,status,created" doesn't exist for include_fields argument>
Prince Nyeche
March 28, 2024
Hey @Birgit Saalfeld
There's no difference between the method export_issues and issue_export as both reference the same object. However, when dealing with fields argument, the names of the fields are case-sensitive and have to be represented the way they appear on Jira.
For example, if you're looking for these fields
You have to call it this way
fields = ["Key", "Reporter", "Issue Type", "Status", "Created"]
An empty list of the fields argument will prevent the lookup of those fields. If your use case is to include certain fields, you have to use the exact name of the field the way they are represented on Jira. Subsequently, you could select the columns on your Jira UI advance search and use the field_type argument with the value "current" to export the same field columns as they appear on Jira UI.
Birgit Saalfeld April 2, 2024
Thank you so much for your fast and helpful answer. Your example worked fine for my test project.
However, I am still facing problems regarding the naming.
Your sentence "However, when dealing with fields argument, the names of the fields are case-sensitive and have to be represented the way they appear on Jira." makes me curios.
When I apply my query against the Iira-Instance where I must export the issues from, it seems, that the don't have a "key"-Information. The following code snippet works without the "Key" argument.
jql = "project= KKN AND issuetype != Sub-task and createddate > '2024-03-22' ORDER BY key"
fields = ["Zusammenfassung", "Autor", "Sprint" ]#"cf[10064]"
issue_export(jql=jql,include_fields = fields, final_file=export_file, extension="csv", encoding="utf-8", delimit=";")
As soon as i add "Key" (or the listed alternatives) to the fields variable, the request fails with following message.
#Alternatives tried: "Issue Key", "Key", "key", "issue key", "Schluessel", "Vorgangsschlüssel", "Vorgangs-ID"
JiraOneErrors: <JiraOneError: Unable to find initial field, probably such field "Key" doesn't exist for include_fields argument>
What could be the reason?
Prince Nyeche
April 3, 2024
I'm not entirely sure why that happens for your environment but I suggest using the next best alternative which is the field_type argument that would give you exactly the export you need if the include_fields argument keeps throwing an error about the "Key" field not being available.
Like Birgit Saalfeld likes this
Birgit Saalfeld April 10, 2024
Dear @Prince Nyeche
the workaround with field_type="all" works fine. I still don't know, why the Jira-instance behaves in such a weird way. Thanks a lot.
Mario Coluzzi April 27, 2024
Has anyone found a limitation on this app? I have 15.000 Issues, only 12.500 have been dumped.
I had this error "IndexError: list index out of range"
ELFAPP Technologies
May 17, 2024
You can follow this discussion and use the app mentioned to achieve the same result via a GUI if you aren't familiar with REST API or scripting.
Henry Santos
August 12, 2024
We are looking to see if this will work for us when migrating issues from Jira server to JSM but a question we had is --- when using this method and the resulting CSV file is imported via the External Systems Importer in JSM, will internal comments maintain their visibility and remain as internal comments? Currently when importing a CSV file, the internal comments end up becoming public comments. Thank you!
Aron Gombas _Midori_
@Henry Santos I think exporting to and importing from CSV will harm the precision of the data in multiple ways. What you mentioned is probably just one.
If I were you, I'd get a trial license for Jira Data Center, use that temporarily (30 days should be more than enough) and use the Atlassian migrator tools to move my issues from DC to Cloud. It should result with zero or very little loss of details.
Henry Santos
August 12, 2024
@Aron Gombas _Midori_ -- Ok we do have Datacenter and our challenge would probably be the same, which is how we go about moving our Jira Server data onto Datacenter while keeping its integrity. For added context: Our Jira Server is on a version that's not compatible with the Migration Assistant app so that adds to the complication.
Our Jira server instance is no longer supported and our partner only migrated some of the data into Datacenter, we are left to figure out how to get the rest of the more recent data over by ourselves.  (The issue with our partner not helping migrate the rest of our data is a long story but that's where we are at this point).
Prince Nyeche
August 19, 2024
Hey @Henry Santos
This should be an easy problem to fix. Typically, you can get the current visibility of each ticket and update the comment with that visibility. Each ticket has a key via API as
"jsdPublic": true
Unfortunately, CSV options don't add the visibility part for comments according to this feature JRACLOUD-64464. So your best option is practically programming your way to achieve this result which should be relatively easy to accomplish. As long as you still have the source data from where a script can perform a lookup, then the problem is fixable.
Rodolfo Arriesgado So
September 1, 2024
Hi  @Prince Nyeche ,
Can you able to provide the complete script for this? Thanks
file_writer(folder, file_name,
content=issues.content.decode('utf-8', errors="replace"),
mark="file", mode="w+")
Prince Nyeche
September 2, 2024
Hey @Rodolfo Arriesgado So
You can add these argumentserrors, and encoding to the issue_export function, and the function will use those when writing the output into a CSV file. However, the script will automatically use the default encoding and replace it if a character can't be decoded within the script. You can look into the code to see the implementation. Understanding your use case or the problem you're facing will let me help you better.
Reinaldo
November 14, 2024
@Prince Nyeche The lib is still available, please? I can't install it:
pip install jiraone
Collecting jiraone
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000015921750908>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)': /simple/jiraone/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000159217503C8>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)': /simple/jiraone/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000015921750A58>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)': /simple/jiraone/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000159217505F8>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)': /simple/jiraone/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000015921750E80>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)': /simple/jiraone/
Could not find a version that satisfies the requirement jiraone (from versions: )
No matching distribution found for jiraone
Learn more
