How to retrieve users from a specific group with simple Jira automation rules
If you’re using Jira Service Management, you may find yourself searching for a quick way to find all users who belong to a specific group and apply automations in Jira. You always have an option to add users one by one right to the request for assignment, approvals, or simply as participants, but it may be too time-consuming. There is also a chance that the person you need is off work, and with group automation you have other people being able to pick up the request. Let’s have a look at a couple of usage scenarios and workarounds we’ve elaborated.
Scenario 1: security change approval
Though Jira was updated recently, with the feature to use Approval groups added, it still does not cover all user needs. So we came up with the following automation rule to help you use groups in automations faster and easier.
Imagine, you need to approve a security change with the Security group before it comes to CAB approval, or you want to receive approval from the Security group for the user requesting antivirus software. To be sure everything goes smoothly, you want to implement a smart approval process in Jira Service Management, and populate all members of a specific group (for example Security group) as approvers.
  1. To retrieve group members, send a call into Jira API using the automation web request action:
https://<your_domain>.atlassian.net/rest/api/3/group/member?groupname=<group_ name>
You can find more details on web request authorization here, if you are interested.
 2. Put a response in a variable which can be later used within the automation rule:
3. Now put the groupMembers variable into the Approvers field and:Picture 13.png
Scenario 2: group assignment
Your Jira Service Management requests are assigned to specific groups based on the nature of the request. There are no group assignments out of the box, so we usually use the Assignment group approach. And as soon as the request is assigned to a specific group you want to make sure that the assignee (which is a single-user field in Jira — the user who is responsible for the request) belongs to the Assignment group”\ set in the request.
  1. To retrieve all group members you have to send an API call:
https://<your_domain>.atlassian.net/rest/api/3/group/member?groupname={{issue.Assignment group}}
2. And then put a response in a variable:
members = {{webResponse.body.values.accountId.join("|")}}
 As a result, you have a string variable filled with assignee IDs separated with "|"
Having that set, you now can easily check if {{members}} contains {{assigneeId}}
As you’ve set all automation rules, you can now add an action. If your assignee is in the group, then do nothing, but if not, clear the assignee field and leave a comment, or notify someone for extra moderation of the request.
And that’s it.
Just curious - have you ever faced a challenge like this? If yes, what did you do? Please, share your stories in the comments, and let’s discuss.
6 comments
Andrey Kiyanovsky
Hi Alex,
Thank you for the article.
1. As I can see, the '/group/member' API request is a paginated request, and it's not handled in your example. So, there should be a cycle of REST API calls, interesting use case to implement. For the second scenario, we can use '/user/groups' call instead to avoid using a cycle.
2. I believe there is a typo with {{/}} at the end of the URL in the first screenshot.
Like 2 people like this
Alex Kiselev _Itransition_
November 30, 2022
Hi @Andrey Kiyanovsky
Thank you for the comment.
#1
Yes, you're right. These scenarios are for groups with up to 50 users. The approval groups as a rule don't contain many users. And this automation completely covers all our needs. But, sure if you have a large group you should use a cycle.
I will prepare the additional rule for building the list of approvers in a cycle.
You are right - for the second scenario, we can use '/user/groups' to find user groups and check if the list contains an Assignment group.
#2
Correct, it's a mistype while preparing pictures for the article.
Thank you!
mb
February 27, 2024 edited
Thanks, this helped me a lot. Even though I use the displayName attribute to list the group's members because I cannot figure out how to e.g. mention all the users by their accountId.
And I used {{groupName.urlEncode}} because my group names have spaces etc. to make sure nothing goes wrong if there are special characters present in the group's name.
Harsh
March 4, 2024 edited
HI @Alex Kiselev _Itransition_
After following the steps for scenario 1, the approvers value still did not get population even after the automation rule is success.
Any idea where things could go wrong, I even used LOG action to debug, up until variable name - {{groupMembers}} the log says values are getting fetched but when editing the Approvers it says NONE.
In my JSON load, I do not see accounId but I see "name"(which hold the ID) and 'emailAddress'. WHen I use Email address - i get the following error - Could not find usernames:, error editing the issue.
Is it possible to somehow do with these?
@mb any suggestion on the above?
March 4, 2024
Hi @Harsh ,
As mentioned in comments above there is a typo with {{/}} at the end of the URL in the first screenshot.
So when you receive the response of the https://<your_domain>.atlassian.net/rest/api/3/group/member?groupname=<group_ name> (you can try URL in browser) - it should be the list of accounts. In case there a couple of accounts (we don't need pagination) - they could be placed into variable as it shown on screenshot 2.
Alexander Ziegltrum
Hello @Alex Kiselev _Itransition_
thanks for sharing the initial solution.
I just wanted to check in, did you ever make it to parse a group with more than 50 users in an automation?
