How to set select lists (single, multiple, cascading), radio or checkboxes on create issue with REST
This small how-to is all about setting custom fields on creating an issue. Apart from the customfield_xxxxx elements, only the minimum required fields are set.
The REST API endpoint
POST https://myjiradomain.com/rest/api/2/issue
HTTP Headers to be set
  • Content-Type: application/json
  • User-Agent: x (required only, if you get an XSRF from browser)
  • Origin: https://myjiradomain.com (required only, if you get an XSRF)
JSON request body for Select List (single choice) / Radio Buttons
"fields": {
  "project": {
"key": "REST"
  "summary": "Issue created from REST API",
  "issuetype": {
"id": "1"
  "customfield_10100": {
"value": "First"
JSON request body for Select List (multiple choices) / Checkboxes
"fields": {
"project": {
"key": "REST"
"issuetype": {
"id": "1"
"customfield_10200": [
"value": "Apple"
"value": "Banana"
JSON request body for Select List (cascading)
"fields": {
  "project": {
"key": "REST"
  "issuetype": {
"id": "1"
  "customfield_10300": {
"value": "Mammal",
"child": {
"value": "Elephant"
JSON request body for Select List (cascading) with 'none' on child option
"fields": {
  "project": {
"key": "REST"
  "issuetype": {
"id": "1"
"value": "Mammal",
"child": null
Tested with Jira Software Server 8.13.3.
7 comments
Community moderators have prevented the ability to post new comments.
Srikanth Ganipisetty
This article is good. Thanks @Thomas Deiler
Like • Thomas Deiler likes this
Ian Hayse
November 2, 2022
Thank you!  I was trying to overcomplicate updating a checkbox field.   For some reason, I thought there was an internal value for each checkbox that needed to be set.
wrong way:
"value": "1000009"
"value": "1000010"
correct
"value": "Apple"
"value": "Banana"
Majo Francis _MicroGenesis Techsoft_
'Group Picker' Custom Field :
"customfield_10073":
"name" : "gname"
Debabrata Pramanik August 11, 2023 edited
I have a asset object custom field, which I want to set during ticket creation. The following does not work there. The call goes through, but the custom field is still empty.
"customfield_10100" : [{"key" : "TEST-1"}]
Maximilian Floß January 29, 2024
@Thomas Deiler
What is the code when both fields of cascading select list should be Emtpy/null?
"fields": {
  "project": {
"key": "REST"
  "issuetype": {
"id": "1"
null,
"child": null
Thomas Deiler
@Maximilian Floß Does your JSON work?
Melissa Nielsen
Just wanted to chime in and say that if you also want to submit a child value in the cascading select list, you have to add "value" as shown here:
Like • Edimara Souza likes this
Learn more
