Introducing Action items in Jira
61 comments
Apryl Harris
@Jennifer Choban - HeroCoders
Herocoders Checklist template app is nice!
But, at my org, expenses are being carefully scrutinized and every bit of savings helps. So, no funding for the paid version (Pro) of the option you recommended, which is what we need to get more templates.
Thanks for recommending though.
Like # people like this
Rachel Hechter
December 4, 2024
Thank you JIRA for this nice QoL improvement!
Daniel Lux
December 4, 2024
We totally need an integration for the Wiki Markup Renderer (for Default Texts; Text Formatting Notation Help - Create and track feature requests for Atlassian products.)
For use cases like DoD this feature is useless without the possibility to use them in a default text or automations.
Danny
December 5, 2024
A great feature, Atlassian dev teams, I'm hoping if anyone at Atlassian could confirm if this would be markdown supported to be able to easily add it into text fields during the execution of an automation rule.
Daniel Zins
December 5, 2024
Thanks for adding that checkbox feature. I was waiting for this since a few years.
Next requirement would be to use it for Automation too, for example auto create a DOD checklist once a story is created.
Dennis Kohl
"Clone Issue" via automation is creating a bullet list instead of cloning the full issue with action items (checkboxes) inside.
  • Action Item 1
  • Action Item 2
That shouldn't happen...
If we want to clone a sheep, we want to get another sheep, not a billy goat :)
BUG Ticket is created if anyone needs this too:
[AUTO-1612] Clone action clones an issue with Action items converted into Bullet list - Create and track feature requests for Atlassian products.
Trudy Claspill
Are there any plans for a Jira Macro in Confluence that could pull specifically the Action Items from Jira issues for display in Confluence; perhaps picking up the issue key, Assignee and Due Date from the source issue?
Like Susan Waldrip likes this
Ahmud Auleear
December 9, 2024
Hey Everyone,
Thanks for the feedback and all the great questions! I'll try to address them all below:
Will the functionality of this feature be extended?
We currently don't have plans to extend the functionality of this feature. However, all the requests made via this post will be reviewed and prioritized against other initiatives in our backlog. Your input is valuable, so please continue to share your thoughts.
When will Action Items be available to all instances?
Action Items has been rolled out to 100% of instances in JSW, JWM, and JSM. If you don’t see it, it might be due to enterprise release tracks. For DC users, this feature is actively being considered. Please vote and comment on the ticket to help prioritize this feature.
Does Action Items support markdown?
Yes! Action Items respect markdown:
  • [] will create an unchecked checkbox.
  • [x] will create a checked checkbox.
Can Action Items be used via Automation?
The ability to use Action Items via Automation is an interesting concept. I’ll review this request with the Automation teams to explore the possibilities.
Can Action Items be used in the Portal Editor?
Action Items were not designed to be active in the Portal Editor, so this functionality is not available at this time.
Bug Reports
Thank you for the bugs. We will triage them and prioritise them.
Ahmud
Dennis Kohl
Hello Ahmud,
Thank you for the information. I have a question about the prioritization of the bug fix.
The BUG I reported is still marked as “low” priority, which is the only priority I can see.
The original request for Jira checkboxes, along with similar linked issues, had nearly 900 votes. This issue has 1,000 votes: Checkbox on Description Field
I’m surprised it’s still gathering votes even though it’s as old as the original request… 9 years. Even more surprising is that it took 9 years to be addressed while Confluence already had this Action Item feature.
My question is: Will the bug fix in its current state take years as well?
I’m concerned.
Best regards,
Dennis
Denys Kontorskyy_Railsware_
Will Action Items eventually support automations, or will add-ons remain the go-to for that functionality?
Ben Robbins
Any plans for this to come to Jira Data Center?
Nicole Shepherd
Probably should update the doc to indicate that instead of “ [ ]” it should be []. That space in between doesn't work.
Khai Ha
Here's another voice advocating action items be added to automations.
Rudy Holtkamp
 @Ahmud Auleear do you have any feedback about your query with the Automation teams?
Nikita Vikhliaev
January 6, 2025
@Ahmud Auleear as reported by others, it doesn't seem the markdown fully works yet.
Anything like '[]' , '[ ]' , '[x]' etc just get rendered as regular text in fields that use wiki-renderer.
The markdown *only* works inside the rich text editor (e.g. when you're typing a comment). But if I just SET the value of a field (such as via Automation) and specify the markdown, it doesn't get recognized.
That said, I can understand how the full implementation of markdown can be complicated. For example, if a Field is not part of a Edit Screen (i.e. is not editable), then how should Action Items interact? Should users be able to "check" them still? But then that is considered "editing" . So Action Items may need to be only supported on editable fields
Floris January 17, 2025
Is there any way to add checkboxes to issues imported using the bulk import from CSV?
I tried it using [] in the description, but it just gives me that as plain text and not as a checkbox.
@Floris I don't know if you can do this with Action Items, but it is possible with Checklist for Jira - https://docs.herocoders.com/checklist/importing-checklists-from-csv-file-to-existing-iss
Michelle Kappauf
January 24, 2025
Will the Action Items ever work in Canned Responses?
Paul Pavlovsky_AppLiger_
Love seeing all the excitement around Action Items! 🎉 If you’re looking to build on this, our Easy Action Items app might come in handy. You can set up reusable checklist templates and even automate them with triggers like issue creation or updates, plus conditions like labels or issue types.
Check it out here, it's free 😉 Got questions? We’re happy to help!
Maksim Beliaev
Automation is missing. Repetitive tasks usually need a checklist, so this feature should include automation.
Zoltán Lehóczky
February 7, 2025
What's the wiki markup equivalent of action items? I'd need this when creating issue via the API.
Darryl Lee
Unfortunately @Zoltán Lehóczky if you flip back to the first page of comments, you'll see @Martin Böhme was the first to ask the same question.
And unfortunately the answer is, Atlassian has strangely not seen fit to make Action Items easily createable with Markup in the API or Automation.
It's a ton more work, but @Sunny Ape confirmed what I suspected, which is that you can create Action Items via the API, but you have to use the undocumented new "taskList" node type in Atlassian Document Format.
<sandbox>
I feel like somebody wanted to get age old "Checklists in Jira" off of some backlog somewhere, and the Rich Text Editor team got together with the Atlassian Document Format team and knocked it out, but weirdly, NOBODY considered Automation or APIs?
</sandbox>
My other theory is that the devs don't want to support markup any more than absolutely necessary. :-P
Zoltán Lehóczky
February 8, 2025
I see, thank you. Also, I didn't even notice there are multiple pages here, the pager is quite hidden.
Martin Flury
I'm wondering if there is any way to have action items placed via a rule to update description field in the create issue transition.
There a multiple format options, also for the icons like (x) or (/), but [] for the action items do not work.
Any idea to achieve such an action item list in the description, while creating a new issue?
I'd rather not use automation, due to is limitation of number of executions.
Domon
February 24, 2025
It is really disappointing and annoying that Action Items does not work in Automation.
I'm tired of fixing the broken Action Items every day 😢
