It’s now easier to configure fields for child issues
Hi Jira Community,
We’ve made it easier to keep on top of your work by introducing configurable fields for child issues to the issue view.
What’s changing?
From the issue view, you can now:
  • Customize fields: Choose which fields you want to see for your child issues and we’ll save your configuration for the same issue types in your project.
  • Edit fields: Update fields for child issues without having to navigate to each child issue.
  • Sort fields: Sort your child issues so you can find what you need faster.
Why are we making this change?
We’ve consistently received feedback that users want to configure child issues within the issue view, so they don’t need to navigate to each child issue to view and edit them.
What do you need to do?
We’ve started rolling out these changes.
Once you’ve tried configuring fields, we’d love to hear your feedback! Let us know in the comments what’s working and what we can improve.
Thanks from the Atlassian team
15 comments
Ciprian Simu March 6, 2025
Hello! While I do appreciate Attlasian listening to feedback and I'm sure hard work went into this, for my team and I this change is terrible - you can't event assign someone to the task if there are only 2-3 child issues, because the list of people to assign is hidden by the border.  We thought/hoped that this change was a bug. It feels hacky and unpolished. Please take it back or make it optional.
On another note, it would be great if someone could look at bigger impact issues, such as this one that's impacting 163 of your customers to this day:
https://jira.atlassian.com/browse/JRACLOUD-90898
Harrison Ponce
March 6, 2025
Is this for new navigation only? I'm not seeing this view of child issues as a table on my Epics or other parents issues. We are on the old navigation currently.
Mireya Cintora
@Ahmud Auleear  Question, once customized, is this a default for all projects? Or is it specific to each issue type? Is there a document I can reference?
Sunelle Delport
March 11, 2025
I have an issue where the child tasks from this table are opened in a new tab and it is very annoying and slows down my team's work significantly. Please can it be changed so child tasks open in a centre or side view like before.
Like Fabio Gavinelli likes this
ConnXpert
This change does provide some benefits when viewing issues in the child panel. However, the change removed the ability to open the child issues in the center of the same tab. So now when you click on a child issue it opens in a new tab. This is a step backward for the child issue panel. Here's a feature request to restore the functionality of opening an issue in the center of the same tab. Please vote if you agree the functionality should be restored.
https://jira.atlassian.com/browse/JRACLOUD-93599
Like # people like this
Sunelle Delport
March 12, 2025
@ConnXpert I'm not sure how to vote using this link, please help me out?
ConnXpert
@Sunelle Delport  After you click the link, you may need to log in by clicking the log in button in the top right corner. You should then be able to click on "Vote for this issue". Hope this helps!Screenshot 2025-03-12 at 9.50.54 AM.png
Ciprian Simu March 13, 2025
When trying to assign someone to a child issue, the list of potential assignees is hidden by the UI - this means that for each subtask I must navigate in a separate window to assign. Very unfriendly UI - please fix or revert to the old experience. This is slowing our team down.Screenshot 2025-03-13 at 10.48.23.png
Zaboor Hussain March 14, 2025
@Ciprian Simu  the fix for your issue is simple scroll over the column end the <-> symbol will appear and you can adjust so the assignee fits on the screen and then it will save your view for future:
@ConnXpert I understand your frustration. The new window view works and as a workaround you can press the back button in the browser to go back to the previous page.
Perhaps they need to allow an option to open within the same middle view and a new page view - I guess they could manipulate clicking the key does one thing and clicking the summary does another.
Ciprian Simu March 14, 2025
@Zaboor Hussain I believe the issue I highlighted is not clear. I'm not interested in resizing the window horizontally, the problem I'm facing is on the vertical axis.
To repro:
1. Create new task
2. Add 1 or 2 subtasks
3. Try to assign someone to them
Benjamin Weinheimer-Erben (mgm-tp)
March 17, 2025
Hi together,
is there a way that a project admin or a system admin can define a default set of fields shown in the Children Panel?
As far as i have tested, each and every one of my users have to configure the panel by themself.
As for most developer this is a nice feature, we have a lot of business-projects in which most users are not able or not willing to configure each and every one of the Children Panels for each issue type and each project. They either expect in an enterprise environment to get proper configured views in the first place.
Marvin Röger
March 19, 2025
Hi everyone,
for our teams this is a real benefit. Unfortunately, the columns need to be added for each individual task and each user has to do it by himself.
We would appreciate, if the users could set their own default configuration, so the same columns are shown in every issue depending on the logged in user or a project based default setting, that can be managed by the project administrator.
Zaboor Hussain March 19, 2025
Do we know what the change window is for this update? as not all features have been pushed out yet?
