×Hello!
In my previous article I showed how to create your own docker image with Atlassian Jira Data Center for M1 processors. But it is not enough for development of apps. We need to start 2 nodes and each node should be available for connecting in debug mode. I intended to modify my Dockerfile but then I found this repo which says that it can create an image of Jira Data Center for M1 processors. I tried it but it did not work for me. I made a couple of changes.
First of all I changed the base image in Dockerfile to
ARG BASE_IMAGE=arm64v8/adoptopenjdk:11.0.11_9-jdk-hotspot
And the file started to look like this
FROM $BASE_IMAGE
ENV RUN_USER jira
ENV RUN_GROUP jira
ENV RUN_UID 2001
ENV RUN_GID 2001
# https://confluence.atlassian.com/display/JSERVERM/Important+directories+and+files
ENV JIRA_HOME /var/atlassian/application-data/jira
ENV JIRA_INSTALL_DIR /opt/atlassian/jira
WORKDIR $JIRA_HOME
EXPOSE 8080
CMD ["/entrypoint.py"]
ENTRYPOINT ["/tini", "--"]
RUN apt-get update && apt-get upgrade -y \
&& apt-get install -y --no-install-recommends fontconfig python3 python3-jinja2 \
&& apt-get clean autoclean && apt-get autoremove -y && rm -rf /var/lib/apt/lists/*
ARG TINI_VERSION=v0.19.0
RUN arch=$(dpkg --print-architecture); \
case "$arch" in \
arm64) export ARCH="-arm64" ;; \
*) export ARCH="" ;; \
esac; \
url="https://github.com/krallin/tini/releases/download/${TINI_VERSION}/tini${ARCH}" ; \
curl "$url" -Lo /tini ; \
chmod +x /tini
ARG MYSQL_DRIVER_VERSION=5.1.49
RUN export JIRA_LIB=$JIRA_INSTALL_DIR/lib \
&& mkdir -p $JIRA_LIB \
&& export MYSQL_FILE_BASE=mysql-connector-java-$MYSQL_DRIVER_VERSION \
&& export MYSQL_FILE_TAR=$MYSQL_FILE_BASE.tar.gz \
&& export MYSQL_FILE_BIN=$MYSQL_FILE_BASE-bin.jar \
&& export MYSQL_DOWNLOAD_URL=https://dev.mysql.com/get/Downloads/Connector-J/$MYSQL_FILE_TAR \
&& rm -f $JIRA_LIB/mysql-connector-java*.jar \
&& curl $MYSQL_DOWNLOAD_URL -Lo $MYSQL_FILE_TAR \
&& tar xzf $MYSQL_FILE_TAR --strip=1 \
&& cp $MYSQL_FILE_BIN $JIRA_LIB/$MYSQL_FILE_BIN
ARG JIRA_VERSION
# The link may change from version to version, check
# https://www.atlassian.com/ru/software/jira/download-archives
ARG DOWNLOAD_URL=https://product-downloads.atlassian.com/software/jira/downloads/atlassian-jira-software-${JIRA_VERSION}.tar.gz
RUN groupadd --gid ${RUN_GID} ${RUN_GROUP} \
&& useradd --uid ${RUN_UID} --gid ${RUN_GID} --home-dir ${JIRA_HOME} --shell /bin/bash ${RUN_USER} \
&& echo PATH=$PATH > /etc/environment \
&& mkdir -p ${JIRA_INSTALL_DIR} \
&& curl -L --silent ${DOWNLOAD_URL} | tar -xz --strip-components=1 -C "${JIRA_INSTALL_DIR}" \
&& chmod -R "u=rwX,g=rX,o=rX" ${JIRA_INSTALL_DIR}/ \
&& chown -R root. ${JIRA_INSTALL_DIR}/ \
&& chown -R ${RUN_USER}:${RUN_GROUP} ${JIRA_INSTALL_DIR}/logs \
&& chown -R ${RUN_USER}:${RUN_GROUP} ${JIRA_INSTALL_DIR}/temp \
&& chown -R ${RUN_USER}:${RUN_GROUP} ${JIRA_INSTALL_DIR}/work \
&& sed -i -e 's/^JVM_SUPPORT_RECOMMENDED_ARGS=""$/: \${JVM_SUPPORT_RECOMMENDED_ARGS:=""}/g' ${JIRA_INSTALL_DIR}/bin/setenv.sh \
&& sed -i -e 's/^JVM_\(.*\)_MEMORY="\(.*\)"$/: \${JVM_\1_MEMORY:=\2}/g' ${JIRA_INSTALL_DIR}/bin/setenv.sh \
&& sed -i -e 's/-XX:ReservedCodeCacheSize=\([0-9]\+[kmg]\)/-XX:ReservedCodeCacheSize=${JVM_RESERVED_CODE_CACHE_SIZE:=\1}/g' ${JIRA_INSTALL_DIR}/bin/setenv.sh \
&& touch /etc/container_id \
&& chown ${RUN_USER}:${RUN_GROUP} /etc/container_id \
&& chown -R ${RUN_USER}:${RUN_GROUP} ${JIRA_HOME}
# Must be declared after setting perms
VOLUME ["${JIRA_HOME}"]
COPY components/entrypoint/ /
COPY components/support/ /opt/atlassian/support
COPY components/config/ /opt/atlassian/etc/
Then I modified a bit the build-image.sh file
#!/bin/zsh
set -x -o errexit -o pipefail
REPO="arm64/jira-software"
JIRA_VERSION="9.2.0"
MYSQL_DRIVER_VERSION="5.1.49"
# tini is a small helper library for Docker containers https://github.com/krallin/tini
# It makes sense to update.
TINI_VERSION="v0.19.0"
docker build \
--no-cache \
-t "$REPO:$JIRA_VERSION-arm64" \
--build-arg JIRA_VERSION="$JIRA_VERSION" \
--build-arg MYSQL_DRIVER_VERSION="$MYSQL_DRIVER_VERSION" \
--build-arg TINI_VERSION="$TINI_VERSION" \
And after it I ran ./build-image.sh
After the image had been created, I ran the following docker-compose.yml file
version: '3'
services:
jira_node_1:
depends_on:
- postgresql
image: arm64/jira-software:9.2.0-arm64
networks:
- jiranet
volumes:
- /Users/alexm/projects/prometheus/jira/shared:/var/atlassian/application-data/jira/shared
ports:
- '8080:8080'
- '8000:8000'
environment:
- 'ATL_JDBC_URL=jdbc:postgresql://postgresql:5432/jiradb'
- 'ATL_JDBC_USER=jira'
- 'ATL_JDBC_PASSWORD=jellyfish'
- 'ATL_DB_DRIVER=org.postgresql.Driver'
- 'ATL_DB_TYPE=postgres72'
- 'JVM_MINIMUM_MEMORY=2048m'
- 'JVM_MAXIMUM_MEMORY=4096m'
- 'JVM_SUPPORT_RECOMMENDED_ARGS="-agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=*:8000"'
- 'CLUSTERED=true'
- 'JIRA_NODE_ID=node_1'
logging:
# limit logs retained on host to 25MB
driver: "json-file"
options:
max-size: "500k"
max-file: "50"
jira_node_2:
depends_on:
- postgresql
networks:
- jiranet
volumes:
- /Users/alexm/projects/prometheus/shared:/var/atlassian/application-data/jira/shared
ports:
- '8081:8080'
- '8001:8000'
environment:
- 'CLUSTERED=true'
- 'JIRA_NODE_ID=node_2'
logging:
driver: "json-file"
options:
max-size: "500k"
max-file: "50"
postgresql:
image: postgres:9.5-alpine
networks:
- jiranet
volumes:
- postgresqldata:/var/lib/postgresql/data
ports:
- '5432:5432'
environment:
- 'POSTGRES_USER=jira'
# CHANGE THE PASSWORD!
- 'POSTGRES_PASSWORD=jellyfish'
- 'POSTGRES_DB=jiradb'
- 'POSTGRES_ENCODING=UNICODE'
- 'POSTGRES_COLLATE=C'
- 'POSTGRES_COLLATE_TYPE=C'
logging:
driver: "json-file"
options:
max-size: "500k"
max-file: "50"
volumes:
postgresqldata:
external: false
networks:
jiranet:
driver: bridge
And as a result I had 2 nodes of Jira Software in debug mode. You can read more about this docker-compose.yml file in my previous article.
Alexey Matveev
software developer
MagicButtonLabs
Philippines
1,577 accepted answers
0 comments
