List custom fields for a Jira Cloud Project with Python
Hi Atlassian Community!
I'm excited to share another handy Python script that simplifies some of your Jira Admin tasks. This time, I'm providing a script that crafts a comprehensive list of all custom fields used in a specified Jira project. This can be particularly useful for administrators managing extensive projects with numerous custom fields.
The solution
The script leverages the Jira REST API to identify and list all custom fields associated with a specified project. It provides details such as field IDs, names, and types, and outputs the data into a CSV file for easy reference and documentation.
Key features
  • Comprehensive listing of custom fields
  • Detailed custom field metadata (ID, name, type)
    (Jira custom field types)
  • CSV export for easy sharing and documentation
  • Projects might have different issue types and different custom fields for each issue type, the script will consider this and query each of the project's issue types to find the related custom fields
Preparation
Install the necessary python libraries by running:
pip install requests pandas
Prepare your Jira Cloud site URL (your-domain.atlassian.net), email address, and API token. You can generate an API token from Atlassian's account security page.
Have the project key ready for the project you wish to analyze
The script
import requests
from requests.auth import HTTPBasicAuth
from getpass import getpass
import pandas as pd
import logging
import os
# Configure logging to show INFO level messages
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
def get_jira_auth():
    jira_domain = input("Enter your Jira domain (e.g., your-domain.atlassian.net): ")
    email = input("Enter your Jira email: ")
    api_token = getpass("Enter your Jira API token: ")
    return jira_domain, HTTPBasicAuth(email, api_token)
def get_project_issue_types(jira_domain, auth, project_key):
    url = f"https://{jira_domain}/rest/api/3/project/{project_key}"
    response = requests.get(url, auth=auth)
    response.raise_for_status()
    data = response.json()
    return [issue_type['name'] for issue_type in data['issueTypes']]
def get_example_issue_key(jira_domain, auth, project_key, issue_type):
    jql = f"project={project_key} AND issuetype={issue_type}"
    url = f"https://{jira_domain}/rest/api/3/search"
    params = {"jql": jql, "maxResults": 1}
    response = requests.get(url, auth=auth, params=params)
    issues = response.json().get('issues', [])
    return issues[0]['key'] if issues else None
def get_issue_fields(jira_domain, auth, issue_key):
    url = f"https://{jira_domain}/rest/api/3/issue/{issue_key}?expand=names"
    return response.json()['names']
def get_all_fields(jira_domain, auth):
    url = f"https://{jira_domain}/rest/api/3/field"
def translate_field_type(field_type):
    translation_map = {
        "option": "Select List (single choice) or Checkbox",
        "user": "User Picker",
        "string": "Text Field",
        "array": "Labels",
        "datetime": "Date Time Picker",
        "number": "Number Field",
        "date": "Date Picker",
        "team": "Team Field",
        "group": "Group Picker",
        "option-with-child": "Select List (cascading)"
    return translation_map.get(field_type, "N/A")
def main():
    jira_domain, auth = get_jira_auth()
    project_key = input("Enter the project key: ")
    try:
        issue_types = get_project_issue_types(jira_domain, auth, project_key)
        logging.info(f"Issue types found: {issue_types}")
        example_issues = {}
        for issue_type in issue_types:
            issue_key = get_example_issue_key(jira_domain, auth, project_key, issue_type)
            if issue_key:
                example_issues[issue_type] = issue_key
                logging.info(f"Example issue for {issue_type}: {issue_key}")
            else:
                logging.warning(f"No example issue found for {issue_type}")
        custom_field_names = {}
        for issue_type, issue_key in example_issues.items():
            fields = get_issue_fields(jira_domain, auth, issue_key)
            custom_field_names.update(fields)
        all_fields = get_all_fields(jira_domain, auth)
        custom_fields_info = [
                'Cloud URL': f"https://{jira_domain}",
                'Project Key': project_key,
                'Field ID': field['id'],
                'Field Name': custom_field_names.get(field['id'], field['name']),
                'Field Type': field['schema']['type'] if 'schema' in field else 'N/A',
                'Translated Field Type': translate_field_type(field['schema']['type'] if 'schema' in field else 'N/A')
            for field in all_fields if field['id'].startswith('customfield_') and field['id'] in custom_field_names
        df = pd.DataFrame(custom_fields_info)
        csv_file = f"{project_key}_custom_fields.csv"
        df.to_csv(csv_file, index=False)
        absolute_path = os.path.abspath(csv_file)
        logging.info(f"Custom fields report generated and saved to {absolute_path}")
    except Exception as e:
        logging.critical(f"An unexpected error occurred: {e}")
if __name__ == "__main__":
    main()
Sneak Peek
Disclaimer:
While this script is designed to facilitate certain interactions with JIRA Software Cloud as a convenience, it is essential to understand that its functionality is subject to change due to updates to JIRA Software Cloud’s API or other conditions that could affect its operation.
Please note that this script is provided on an "as is" and "as available" basis without any warranties of any kind. This script is not officially supported or endorsed by Atlassian, and its use is at your own discretion and risk.
Cheers!
3 comments
Matt Doar _Adaptavist_
Thank you for the sample code. I'm interested in why you chose to use requests rather than the commonly used Jira Python library at https://jira.readthedocs.io/ ? Any thoughts welcome
Delfino Rosales
February 21, 2025
Hi Matt!
I'm not that familiar/comfortable with the Jira Python library referenced but I'll definitely give it a try in future scripts.
Cheers!~
Rick Westbrock
I have tried that library but sometimes I want more flexibility and I think the last time I tried it there was something it couldn't do for me so I had to write my own code to accomplish it (no idea what that was at this point however).
