×Hi, Atlassian community,
We’ve read your comments about the new issue view, gathered common themes, and wanted to address them in its own post. We understand that this likely won’t solve all your problems with the new issue view, but hopefully, it’ll help you work with it in a way that better fits your team.
For those who have specific suggestions or how to improve the new issue view, comment and vote for it here (each specific suggestion is a subtask). If it’s not here, lodge a suggestion.
Our team looks at the most commented and voted suggestions on the JAC ticket, so bringing your thoughts there will better ensure your voice is heard.
If you’re having issues with the new issue view’s layout, we recommend contacting your admin to configure the layout of the issue view. See this doc here: https://support.atlassian.com/jira-software-cloud/docs/configure-field-layout-in-the-issue-view/
Some common problems and solutions:
Q: The old issue view gave me all my most important information at a glance. How do I make the new issue view do the same?
A: Put your most important fields in the Description fields section, the main focus of the issue view. Everything else can go in the Context fields section, or under field tabs.
Q: How do I get my most important fields at the top?
A: Order your fields in the configuration page by priority. The higher up they are in their respective sections, the higher up they’ll be on the issue view.
Q: I don’t use the right side of the issue view. How do I minimise it?
A: While you can’t hide the right side of the issue view completely, you can minimise it by hovering between the left and right section (for a slider to appear) and dragging it to find a configuration that fits you.
Q: The new issue view is cluttered. How do I make it cleaner?
A: To unclutter the new issue view, try hiding fields you don’t need as much in the More fields section, or under field tabs. You can also remove fields you don’t need altogether.
Q: How do I change the issue type in the new issue view’s layout?
A: Hover over the issue type’s icon in the top left, and select it. A dropdown should appear.
Q: How do I update the Date Time Picker field?
A: Click the Date Time picker to enter the edit mode. A drop with 30 min intervals will appear if you wish to enter a more precise time, enter the desired time.
Thank you for the feedback. Understanding the problems you’re all having with the new issue view is valuable to us, and will help us move towards one issue view that can be customised to fit every team.
Have a Happy Holidays,
Ahmud
Ahmud Auleear
51 comments
