Lately, I have come across a few questions about using workflow properties to restrict actions when issues are on a particular status. Therefore, inspired by this jirakb, I thought it'd be helpful to write a short article to explore another possible configuration - to prevent users from linking issues on a Done status.
The examples and references you will find in this article are primarily related to Jira Cloud company-managed projects. Still, you can apply these configurations to Server/Data Center installations. However, If you're looking for workflow customizations on team-managed projects, check out the Work in Jira Software Cloud team-managed projects documentation.
Basically, workflow properties offer a way to implement restrictions on certain workflow steps or transitions. You can learn more about how to use and configure workflow properties in the following documents:
1 - Edit the workflow step property of the status you want to restrict the ability to link issues.
2 - Select Properties
3 - Add a New Property with the following parameters
For the property value, you should choose a group to grant permission to link issues. Thus, whoever is not a member of the group, won't be able to link issues.
It's important to mention that you can also use different parameters other than groups, such as project role. You also have the ability to configure the same property more than once by adding a suffix with incremental numbers. For example: jira.permission.link.group.1, jira.permission.link.group.2, etc. You can find more details about the available options at Permissions based on Workflow Status.
4 - Go back to the workflow draft and click on Publish Draft. This is easy to forget, but without publishing it, the change won't take effect.
Some of the behaviours you can expect after adding the property:
Before you go, make sure users have the link issues project permission to link an issue. Last, I know there is much more to share about this topic. So, feel free to chime in!
Ivan Lima
Senior Consultant | Atlassian Certified Expert
iTMethods Inc.
Toronto
191 accepted answers
4 comments
