Python script to bulk attach files to Jira Issues in Jira Cloud
Hi Atlassian Community!
It's me again.
I'm sharing a helpful Python script to streamline attaching multiple files to Jira Cloud issues. This script automates the process of uploading files, saving you time and effort, especially when dealing with many attachments.
The solution
The script uses the Jira Cloud REST API (this endpoint specifically) and reads data from a CSV file to attach files to specific Jira issues. The CSV file should contain two columns: "Issue Key" and "Filename". The "Filename" column should contain the paths to your attachment files (either relative paths from where you run the script or absolute paths).
Example:
Issue Key,Filename
PROJ-001,/Users/user1/Desktop/attachments/attachment1.png
PROJ-002,/Users/user1/Desktop/attachments/attachmend2.txt
PROJ-003,/Users/user1/Desktop/attachments/attachment3.pdf
Key features
  • Attach multiple files to multiple issues in one run
  • Uses a CSV file to specify issue keys and file paths, making it easy to manage attachments
  • Includes robust error handling to catch issues like invalid file paths, missing CSV columns, or authentication problems
  • Provides informative logging messages to track the progress and identify any errors
  • Prompts you for your Jira Cloud domain, email, and API token for secure authentication
Preparation
1) Make sure that the user acting on this script has the necessary project permissions to "Browse Projects", "Edit Issues", and "Create Attachments".
2) Ensure the destination issues (issue types) have the "Attachments Field" in their edit screen
3) Considerations: There's a character limit of 256 for file names, also check your attachment size limit to avoid related errors
4) Install the necessary Python libraries by running:
pip install requests
Prepare your Jira Cloud site URL (your-domain.atlassian.net), email address, and API token. You can generate an API token from Atlassian's account security page.
The script
import requests
from requests.auth import HTTPBasicAuth
from getpass import getpass
import logging
import os
import csv
import json
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
def get_jira_auth():
    jira_domain = input("Enter your Jira Cloud domain (e.g., your-domain.atlassian.net): ")
    email = input("Enter your Jira email: ")
    api_token = getpass("Enter your Jira API token: ")
    return jira_domain, HTTPBasicAuth(email, api_token)
def attach_files_to_issues(jira_domain, auth, csv_filepath):
    """Attaches files to Jira issues based on data from a CSV file."""
    base_url = f"https://{jira_domain}/rest/api/2/issue/"
    try:
        with open(csv_filepath, 'r', newline='', encoding='utf-8-sig') as csvfile:
            reader = csv.DictReader(csvfile)
            for row in reader:
                issue_key = row['Issue Key']
                filepath = row['Filename']
                url = f"{base_url}{issue_key}/attachments"
                headers = {
                    "Accept": "application/json",
                    "X-Atlassian-Token": "no-check"
                try:
                    with open(filepath, 'rb') as file_content:
                        files = {"file": (os.path.basename(filepath), file_content)}
                        response = requests.post(url, headers=headers, auth=auth, files=files)
                        response.raise_for_status()
                        logging.info(f"Attachment {filepath} added to issue {issue_key} successfully:")
                except requests.exceptions.RequestException as e:
                    logging.error(f"Error attaching {filepath} to {issue_key}: {e}")
                    if response.status_code == 404:
                        logging.error(f"Issue {issue_key} might not exist or you might not have permission.")
                    elif response.status_code == 403:
                         logging.error(f"Authentication failed, please verify your email and API token.")
                except FileNotFoundError:
                    logging.error(f"Error: File '{filepath}' not found. Please double-check the file path.")
                except KeyError as e:
                    logging.error(f"Error: CSV file is missing a required column: {e}")
                except Exception as e:
                    logging.exception(f"An unexpected error occurred during attachment upload: {e}")
        logging.error(f"Error: CSV file '{csv_filepath}' not found. Please double-check the file path.")
        logging.exception(f"An unexpected error occurred during CSV processing: {e}")
def main():
    jira_domain, auth = get_jira_auth()
    while True:
        csv_filepath = input("""
Enter the path to your CSV file.  The CSV must have columns named "Issue Key" and "Filename".
The "Filename" column must contain valid paths to your attachment files (either relative or absolute).
Examples:
1. CSV in the same directory as the script:
   attachments.csv
2. CSV in a subdirectory called "data":
   data/attachments.csv
3. Full path to the CSV:
   /path/to/your/attachments.csv
CSV File Path: """)
        if csv_filepath.lower().endswith(".csv"):
            break
        else:
            print("Invalid file type. Please enter a CSV file.")
if __name__ == "__main__":
    main()
Disclaimer:
While this script is designed to facilitate certain interactions with JIRA Software Cloud as a convenience, it is essential to understand that its functionality is subject to change due to updates to JIRA Software Cloud’s API or other conditions that could affect its operation.
Please note that this script is provided on an "as is" and "as available" basis without any warranties of any kind. This script is not officially supported or endorsed by Atlassian, and its use is at your own discretion and risk.
Cheers!
2 comments
Matt Doar _Adaptavist_
Nice, thank you!
Might also be worth checking that each attachment name is not too long? (255 chars IIRC). And sadly I've never found a way to set the user name of the person who is supposed to have uploaded the attachment. That info doesn't seem to be displayed any more so it probably no longer matters
Like • Delfino Rosales likes this
Delfino Rosales
February 28, 2025
@Matt Doar _Adaptavist_
That was a good catch, thanks!
Will update the post with this consideration
Best regards,
