Simplified All Work view: one unified column to rule them all
Hi there,
I'm Tanya Maddalena, Product Manager in Jira.  We're making it easier to scan and manage your work in Jira's All Work tab by merging multiple fields into one streamlined column.
Until now, the All Work tab displayed individual columns for the hierarchy button, work item key, type, and summary. This could make the list feel cluttered and harder to scan—especially if you manage a high volume of items.
🚀 What’s changed?
In the All Work tab, you’ll now see a single unified column on the left that combines the hierarchy toggle (for expanding child items), work item key, type, and summary — all in one place.
This column is fixed in position and can’t be moved, so that your key work info stays anchored as you scroll and scan your list.
You can still sort by each individual field! Just click the three dots (…) in the Work item column header and choose which attribute—key, type, or summary—you want to sort by.
And if you're exporting your data, don’t worry: exports remain unchanged. Each field will still appear as its own separate column in CSV or Excel exports, preserving the full detail and structure you're used to.
🌱 Why we made this change
This isn’t just a visual update—it’s a foundational improvement designed to support future UX upgrades and make Jira faster for you.
By consolidating fields into a single column, we’ve created space for more powerful features down the line while improving page performance today. Faster loading times and a smoother scrolling experience are just the beginning.
đź’ˇ How to try it out
To use the merged column in Jira:
  1. Go to your Jira project.
  2. Switch to the All Work tab.
  3. Check out the first column, which now merges hierarchy, key, type, and summary into one neat line.
âś… Benefits
  • Cleaner workspace: Reduces visual clutter by eliminating redundant columns.
  • Faster Jira: Lighter UI means faster load times and better performance.
  • Future-ready: Sets the stage for upcoming UX improvements that build on this new column structure.
  • Streamlined navigation: Quickly find the information you need without juggling multiple columns.
Let us know what you think.
Tanya and the Jira team
14 comments
Avery W. Krouse
I sincerely do not like this change. Sorting a list by summary is one of the most common sorts anyone does and you have now tripled the number of clicks required to do so.
I would ask that you consider putting a sort button back into the header tied to summary and allow the users to use the overflow menu if they want to sort by key or type.
Like • # people like this
Clairee Daniels
@Tanya Maddalena What is the release plan / date for this change?
Rick Westbrock
July 14, 2025
To Avery's point Atlassian sure seems to like moving common operations under a menu which requires more clicks to accomplish which has become pretty frustrating over the past year or so. Fortunately for me we hid the All Work tab on our boards because it didn't provide any additional value compared to the List tab and in fact is worse because it includes resolved work items by default.
Joe Bauers
July 14, 2025
@Tanya Maddalena
Why is this feature impacting the results for Filters if it was only intended to impact the All Work tab?
I don't want these columns grouped together when I run a JQL query.  I want to be able to move the Issue Type, Key, and Summary columns to any column location I want.  However, this change has removed this option from me and anyone else who uses their own custom column order and location for these fields.  To be honest, the formatting in the grouped Work column is annoying if you don't have fixed-width keys, and this is more of a step back than forward in terms of functionality.
Ilona Brockmann
July 15, 2025
I do not like the change, as I am working often with list view and here I cannot select a descending sort by key only. will this be  available in future?
Like • Susan Waldrip likes this
Rick Westbrock
July 15, 2025
I am glad that Joe pointed out that filters are impacted by this change. I had put this aside as not important to me since I hide the All Work tab on my team's boards but now I see that the title of this article is very misleading as the change is not limited to just the All Work tab.
I understand the desire to improve performance but Jira becomes slower for me when I now have to click multiple times to do something which used to require zero clicks. This feels similar to a lot of the UI changes in the past year where it takes several more clicks to perform common actions now than it did before.
Leon Oud July 23, 2025
I agree with Joe Bauers. This change limits the UX of the filter results table for us instead enhancing it. In some cases it can be argued that this is an improvement, e.g. when displaying work items in a hierarchy and when using same size keys, but in the filter it is restrictive, more work and messes up the look and feel is keys of different lengths are used.
I would suggest that this change/hybrid column becomes a separate option in the columns selection, so key and summary can also be chosen as separate columns. Any future features that need this hybrid column can then still be assign only to that hybrid column, while giving users the opportunity to still add the separate columns to the result table.
Karen July 27, 2025
Not a fan of this change. Need 3 clicks to filter by Summary, instead of 1 click.
Giving user preference to merge/split would be better.
Haddon Fisher
August 13, 2025
It would be one thing if this was toggle-able; there are definitely times when the extra real estate is nice. But as long as this is a forced thing, there's no way this can be anything but a "fail".
It's been said already a bunch here, but...and I'm sorry to be salty here but it's absolutely true...I would really appreciate it if Atlassian stop telling us they know better about how we work than we do. I love that y'all want to innovate and make things better, but, despite having a literal horde of folks proactively providing you feedback, you seem to always pick the wrong things to change and then change things in a bad way. This is a great example; this is absolutely not a priority (if even something anyone even asked for), and the resulting execution forces a uniform solution on everyone.
I have low faith that anyone from Atlassian is listening based on even recent history, but if you are: either make this something you can toggle, or just unwind it. It's a cool idea, but at the end of the day this is less functional; as long as you're expecting companies to pay for this, then form kind of needs to follow function. Most of us landed on Jira in the first place because of how configurable it was and how many different use-cases it supports.
Wurm Peter
Please go further and show the full hierarchy regardless in which project an child work item is (as long as user has access rights).
Tapiwa Samkange
Thanks for the update, @Tanya Maddalena . It seems like more features from the List view are being added to the All Work view. Is the plan to eventually sunset the List view
You mentioned that the change is "a foundational improvement designed to support future UX upgrades and make Jira faster", hence the question. If so, please may you point us to the product roadmap which includes the planned changes.
It was good to see that comments are now included in the All Work view, however, I noticed that when the comments in All Work are selected, the behaviour is not the same as in the List view (the comments are displayed in a page, not a pop-up. The user then has to click on 'Return to search' to view the full list. In the List view the list remains visible when the user clicks on comments).
Thank you.
Wurm Peter
@Tapiwa Samkange Yes, the "list view" will be removed one day - as another article is labelled "We’re merging List and All work – one powerful view for all teams".
David Tieman
@Tanya Maddalena  Echoing several other comments about this change and the impact to Filters as well as the All Work option... While touting performance improvements of these and other UX related changes, the performance is actually worse from the position of presenting the JIRA data to teams.  I am finding that I am slower to locate commonly used options as well as needing to click multiple times to get to previously "1st click" options.
Who are the customers that are reviewing these changes and providing feedback?  What size teams do they have? What is the number of "Spaces" (Projects) they are managing? etc.  These changes have had exponential impacts to the ability to locate and execute functions.
Thank you
Like • Julie Hiatt likes this
Rick Westbrock
September 11, 2025
It feels like Atlassian may measure performance strictly from back-end timings and ignore the time spent by the human on the other side to actually access the information they need.
