Note: Following the success of this experiment and our Early Access Program (EAP) in October 2024, we've now launched Beta for the new navigation.
Hi everyone,
The Jira Navigation team has been relentless in its efforts to make finding and resuming your work effortless. Following several weeks of testing, we're excited to expand this experiment to a wider audience and gather more insights from users like you.
If you’re keen on helping us improve this experience, we’d love for you to join us in an experiment so that we can understand the key aspects of your workflow and how you navigate through Jira.
We’re revamping Jira with a modern and easy-to-use navigation system that’s designed for consistency, flexibility, and efficiency.
The key changes in the new navigation are:
Simplified top navigation: We've reimagined the top navigation, decluttering it to keep the focus on essential tasks like search and create. All other product and navigation items have been relocated to the new left sidebar.
Customizable and collapsible sidebar: Customize and collapse sections within the left sidebar to focus on what matters most to you. Personalize your navigation further by showing or hiding the menu items on the sidebar.
Unified look and feel: The new navigation is designed for a cohesive experience across all Jira products, like Jira Software, Jira Work Management, and Jira Service Management, improving co-usage between them.
Effortless project switching: Get to your work faster with fewer clicks, even when working across multiple projects.
See the clear visual changes here.
Navigation (top and side navigation) is central to how users find and move their work forward. While our product portfolio has expanded and evolved over time, the navigation in Jira has become inconsistent, rigid, and difficult to manage.
The current navigation is cluttered and lacks customization: The interface is overcrowded with underused features, making navigation difficult and inflexible. Moreover, users want the ability to customize what they see in Jira.
Inconsistent side navigation across Jira products: Users navigating through multiple products, like Jira Software, Jira Work Management, and Jira Service Management, find it confusing and spend more time adjusting to the context switch.
We’ve developed a Chrome extension to enable the new navigation in Jira. We’d love for you to try the new navigation in your own instances and share your insights with us.
Your insights and participation will greatly contribute to improving the Jira experience for all users. So we urge you to talk to your Jira admins about enabling a Chrome extension from the Chrome Web Store.
Note: The extension is available to use in Chrome browsers only, and we don’t support IE, Safari, or other browsers.
To use the new navigation:
Open the Chrome extension and select Add to Chrome.
Select Add extension and pin it to your Chrome browser so you can easily toggle it on/off.
After you’ve turned on the extension, open your Jira instance. You should see the navigation on the top and side are different. Also, your frequently used menu items may have moved.
If you already have Jira open in your browser window, refresh the page and the new navigation should work for you.
We want you to use Jira the way you would normally, while we intend to understand your usage and preferences so we can refine the navigation experience. Given this is an experiment, we're rolling out a limited set of features, and there may be bugs or unintended behavior. If something isn’t working out for you, you can revert to the old experience by toggling off the extension. You can toggle it back on after you’ve completed the task. We’d like to know why you went back to the old experience.
Read more on identified issues and bugs.
We’d love to hear about your experience using the new navigation in Jira. Share with us:
Any tasks you found challenging to complete using the new navigation
How you've personalized your sidebar to suit your work
What’s working well for you
What’s not working well for you
Any other comments or suggestions, no matter how minor
You can give us feedback on the new navigation after you’ve enabled the Chrome extension by selecting Give feedback from the left sidebar.
If you’ve explored the features and functionalities of the new navigation, please take a few minutes to participate in our brief survey. Your feedback will help us refine the new navigation to better meet your preferences.
Additionally, if you're open to sharing more about your experience through an interview, please sign up here.
Furthermore, you can join our Community group where you can ask questions, share feedback, raise concerns, and connect with the team working on the Jira Navigation.
Varsha Patel
34 comments
