Understanding issue types in jira
65 comments
Abdelrahman ElRuby
September 13, 2021
resolution for board page is now bigger and cannot revert back to original size and now i have to use scroll bar to check the rest of the board
Danny
September 14, 2021
This is great content, thanks
mark wood
October 13, 2021
Well, I find this is a great article for learning the basics of Jira issue types in a quicker manner. keep it up. Great piece of work.
Deleted user November 11, 2021
As  Product Manager, I need another level.  It would look something like this:
  • Epic
    • Story
      • Task
        • Subtask
How can I accomplish this?
Like # people like this
Danny
November 11, 2021
Hi @[deleted]
Simple answer is that is not possible as Task and Story sit at the same level. What you could do though is use Advanced Roadmaps in JIRA and have initiatives as issue types which sit above Epics.
  • initiative
  • Epic
  • story OR task
  • Sub task
hope this helps,
Danny
Deleted user November 12, 2021
Danny I'm not sure how to access the Advanced Roadmaps. I might be able to make this work..
Like Rajesh Viswanathan likes this
Danny
November 12, 2021
You will need a JIRA cloud premium licence if you have JIRA cloud.
Lucas Ferreira
November 24, 2021
Which issue type would enable cross-epics mappings out of the box?
Robson
Parabéns, muito próximo do Guia Scrum...leitura rápida, conteúdo de simples entendimento ...irei levar o artigo como uma colinha para utilizar nas inclusões de demandas no JIRA..
Rob Williamson
February 15, 2022
I have the following options for Issue types:
Issue
Task
Epic
I 'get' Epics (groups of tasks/issues) but what is the difference between Issue (Task) and Issue (Issue) ?
Danny
February 18, 2022
Hi @Rob Williamson ,
An issue is the terminology that Atlassian uses to define the ticket/task/bug/etc.
It sounds as though you have an issue type known as task and another known as Issue. Is that correct?
Danny
liocou
March 4, 2022
C'est tout à fait explicite, et les exemples sont parlants pour une meilleure compréhension
Great Ancheta April 26, 2022
We are using Jira for software development and we have customer support also using another tool. When customer support raises a problem, it takes time to assess the problem before something is classified as a bug or maybe a change request story etc. what’s the best way to track these problems raised to us before they become bugs or stories ?
Letícia Daniel
Thanks a million!
Freddy May 13, 2022
Awesome stuff , I have benefitted greatly as a new fellow here.
Please keep up the good works .
I am preparing for my ACP 620 exam , please give more references like this.
Kindest Regards
Monique Armstrong
May 13, 2022
Thank you for this article... Very precise and clear using the standard Project Issue Types. I will definitely share with my Team.
Adam Sterrie
When explaining issue types to users, I explain that an issue type is a different type of work, and there are only 3 types of work in the universe:
1. story: making something better than it is;
2. defect: fixing something that's fallen below what it should be; and
3. task or doing something which is neither story nor defect but has to be done to achieve the overall goal).
The rest is just "grouping".
I use an analogy of putting up some new shelves. Putting up the shelves is the story/improvement/new feature (it's all basically the same). Buying a drill is a task. Fixing the mess you made putting up the shelves is the defect. You can group issue types together [into epics] but it's just a grouping and you can group epics together into an Initiative which is still just a grouping. A child issue (sub-task or anything else) is just an issue that is split out of the parent but remains an intrinsic part of the parent. Otherwise it's a separate but linked issue.
John S
June 20, 2022
an eye opener
Like luis.ortiz likes this
vikram
August 11, 2022
Excellent and easy to understand
Rosana Ferreira Soares dos Santos
Wow, what a rich material!  Just perfetc.
Lars Fessler
Wow, easy to understand and to the point!
James Castell-Webb
November 21, 2022
What a great way to explain the differences
anhtranIFD
December 28, 2022
Hi @Christina Nelson, thanks for your posts! The content is well-organized and goes straight to the purpose. I just have one concern that has not been mentioned in your post: The definition of Feature Development type in Jira. What is the difference between User story/Feature Development/Task? Does it the sub-type of User story?
Deleted user January 25, 2023
@Christina Nelson Well explained! I will forward the article to my new teammate who has no experience with Jira.
bougares mourad
February 6, 2023
Thank you for this clear presentation of the different issues type. it was a meaningfull way.
