Update October 2023:
Hi all! Most of the functionality outlined below has been rolled out. You can rename the issue hierarchy Level name (for example renaming 'epic' to 'feature') and see that change being applied everywhere.
The remaining work is the introduction of the "Parent" field which replaces the Epic Link and Parent Link field and the JQL changes for this. This has started rolling out for some Beta customers, and we'll roll it out to everyone else as soon as we have completed our Beta group rollout.
To view more details of this "Parent" field work, and to keep track of the progress - head over here: https://community.atlassian.com/t5/Jira-Software-articles/Introducing-the-new-Parent-field-in-company-managed-projects/ba-p/2377758
Thank you!
Updated February 2023: The functionality outlined below in this post is not yet available. We’re currently working at building out these new experiences and will provide additional updates as we get closer to our release date. You can follow the projected GA release date on the cloud roadmap.
Hi Jira Community!
We want Jira to be able to reflect the way teams work, no matter what framework you may or may not use. That’s why we’re looking at providing you with the flexibility to shape our tools to the way you work, starting with the name of your epics in your company-managed projects.
Why start here? We know many teams using Safe Agile Framework (SAFe) struggle because they’re unable to reflect their issue hierarchy in Jira Software Cloud, namely Features as the parent of stories, rather than epics. Non-software teams can also benefit from terminology that better reflects their work, e.g. campaign, candidate, etc.
We hope that these changes will be valuable for all teams, providing you with more control of your issue hierarchy and the epics in your Jira site.
Issue hierarchy configuration will soon have a new home in the global Jira admin settings. This means that teams using Free and Standard Jira will now have the ability to manage their issue hierarchy, up to the epic level.
You’ll be able to access this new settings screen by heading to: ⚙️ Settings > Issues > Issue hierarchy.
What does this mean for you? On this screen, you’ll be able to rename and add issue types to the epic level in your site’s issue hierarchy.
And, changing the name of your epic level is easy! Just click the level name (by default, this will be Epic), type in a new name, and hit Save changes.
Once you’ve changed the epic level name, head over to the Issue types settings screen, and update the name of the Epic issue type to reflect your new level name.
Changes you make to your epic level will be reflected throughout all company-managed projects in your site. For example, if you’ve renamed the epic level to Feature, your backlog will now contain a Feature panel, rather than the existing Epic panel.
Note: As part of these updates, only issue types on the base-level (that’s the default level for stories, tasks and bugs) can have an epic as their parent.
If you’re an Advanced Roadmaps user that has epic links for issues above the epic level, you’ll need to update these epic links by July 5th October 31st, 2022 to ensure this relationship data is not lost. Visit our guide to find out if you're affected and learn what you need to do to maintain your data.
Alongside these updates, we’re making additional changes on the board and backlog to more closely align epics across company-managed and team-managed projects:
The epic color on the board and backlog will now use the epic’s Issue color.
The name of the epic on the board and backlog will now use the epic’s Issue summary.
What does this mean for you? Well, depending on how they’re set up, your epics might look a little different when viewing them on the board and backlog.
For example, issues on your board and backlog will now use the epic’s Issue summary in their lozenge. If the name of your epic and its issue summary are different, then these lozenges will be updated when we roll out these changes.
We’re improving the way you associate epics with your bugs, stories and tasks in the issue view. Currently, this is done via your issue’s Epic link field – we’ll soon be replacing this with a new Add parent feature.
We’ve heard from you that the location of the Epic link field in the issue view can make it difficult to add epics efficiently, so we’re adding the ability to add a parent directly from your issue’s breadcrumb, consistent with how you work in team-managed projects.
You’ll also be able to add a parent from the Actions (...) menu or using keyboard shortcuts.
To reflect these updates, we’re also making some small changes to our JQL functions. The parent() JQL function will extend to incorporate the functionality of the “epic link”, “parent link” and “parentEpic” functions.
While these functions will continue to work in your existing JQL searches, you’ll no longer be able to use them in new searches. Instead, teams should begin using the parent() JQL function.
We’re currently working on building out these new experiences in your company-managed projects, and will provide additional updates as we get closer to our release date. You can follow the projected GA release date on the cloud roadmap.
In the mean time, we’d love to hear your thoughts on these updates, so let us know your feedback and suggestions in the comments below. Thanks!
Q: Can I create issues above the epic level in the issue hierarchy as part of these changes?
A: This feature is currently available for customers on Premium or Enterprise plans.
Q: Where can customers on Premium plans find their hierarchy configuration now?
A: To view the existing hierarchy configuration: In the navigation bar, go to Plans > Settings, and then select Advanced Roadmaps hierarchy configuration from the sidebar.
Q: Will the Advanced Roadmap hierarchy configuration continue to be available when these changes roll out?
A: These changes will combine the existing Advanced Roadmap hierarchy with Jira’s issue hierarchy.
The existing configuration screen in the Advanced Roadmaps settings will redirect you to its new home in the global Jira admin settings.
Q: Will these changes impact how I can edit the levels below epic?
A: Levels below the epic level are unaffected by these changes.
Q: How will these changes impact my automation rules?
A: These changes will affect rules using the following smart value properties:
Epic Link
epic
Parent Link
Atlassian plans to migrate the affected smart values by 31 May 2022 so that Automation rules won’t break. If there are any edge cases we're unable to migrate, we'll communicate this closer to the time.
Q: Will it be possible to rename epics in Jira Server or Data Center products as well?
A: For information on configuring flexible terminology in for Jira Software Data Center, see:
Q: Will there be any impact on the epic panel?
A: The epic panel will respect any changes you make to your epic level name. Listed epics will also begin using their Issue summary. Learn more about these changes.
Q: Do you have more information around the changes to the epic name and epic color?
A: These updates are designed to reduce the use of epic fields in Jira experiences. No existing data in these fields will be lost. Learn more about these changes.
Q: How will this impact queries and reports?
A: Queries and reports will be unaffected by these changes.
Q: Will the portfolioChildIssuesOf function continue to work as part of these changes?
A: The portfolioChildIssuesOf function will be unaffected by the changes.
Rohan Swami
Product Manager - Jira Product Discovery
43 accepted answers
212 comments
