2 workflow in 1 project
Dr_Win_ST
Can we creater 2 workflows in 1  project?
How can i do it, please guide me?
Thank you
2 accepted
Doreen Undiri
November 13, 2024
Hi @Dr_Win_ST
you can use Workflow Scheme  for this,  it allows you to assign workflows to their respective issue types within the same proje
Now to use two different workflows in the same project, you need to create or use existing workflows and then map them to specific issue types through a Workflow Scheme.
Go to Jira Settings > Issues > Workflows and either create new workflows or edit existing ones to match the processes for different issue types. Next, create a Workflow Scheme by navigating to the Workflow Schemes and assigning each workflow to its corresponding issue type (e.g., the "Bug Workflow" to the "Bug" issue type and the "Task Workflow" to the "Task" issue type).
And  apply it to your project by going to the project’s Project Settings > Workflows and selecting Switch Scheme, choosing the Workflow Scheme you just created.
Note: this is applicable to company-managed projects only
Dd
Dr_Win_ST
Thank you so much
Trudy Claspill
Hello @Dr_Win_ST
What type of project are you using? Get that information from the View All Projects page under the Projects menu.
This documentation discussed managing workflows for Company Managed projects.
https://www.atlassian.com/software/jira/guides/workflows/overview#relationship-between-workflow-and-board
Here is another reference that includes a link to comparable documentation for Team Managed projects.
https://support.atlassian.com/jira-cloud-administration/docs/manage-issue-workflows/
Dr_Win_ST
Thank you so much
Register now
