Thanks in advance for any help you can provide.
I am looking for a way to search all past tickets that have rolled over to another sprint for the year. I know you can see what has rolled over from a closed sprint to the current open one but I am hoping to find out a historical list of all rollover tickets. Can we search for any tickets that have advanced a sprint or more?
HI @Carlie Barr , here is an option to consider. Use Automation to inspect the Sprint field for > 1 entries and send that info in an email.
Note: I used Scheduled trigger simply so I could easily run at will from w/in Automations screen. My JQL finds issues resolved since first of the year. Add your email in the red area. The yellow provides the key info to include which I added below for ease of copying.
resolved >= startofyear() and resolved <= endofyear() and Sprint in closedSprints()
Issues in multiple sprints:
{{#lookupIssues}}
{{#if(sprint.join("~").split("~").size.gt(1))}}* {{key}} -- {{summary}}{{/}}
*****credit where credit is due - I picked this up from @Bill Sheboy last year and saved into my personal automation library.
Hi @Carlie Barr ,
Do you have ScriptRunner? Do you move all incomplete issues to a next sprint? If you so, you can do this
(issueFunction in incompleteInSprint("%YOUR_TEAM%", "%YOUR_SPRINTS%")) AND resolutiondate <= endOfYear() and resolutiondate >= startOfYear()
Or you can use the app I developed - Multi-team Scrum Metrics & Retrospective. With it, you can automatically get uncompleted scope across several years, half-years, quarters, months, or sprints for several teams/boards in a single view, and do drill-down (for example 2024 -> 2024 H1 -> 2024 Q1 -> 2024 Jan -> Sprint 1) to figure out where the issues really come from. If you would like to see them in the Issue Navigator. You can click on the 'View in Issue Navigator' button.
Also, you can:
see the difference between periods—does the uncompleted scope increase or decrease for a certain period compared to the previous one?
Best regards,
Alexey
Hello @Carlie Barr
Jira does not have a native JQL function for that. Are you willing to consider getting a third party app to generate such a report?
Alternately you might be able to generate something through use of REST API calls.
Thank you!
