I have a backlog, sprint and board. All of which appear to be configured correctly. I have the correct swimlanes and the correct statuses are mapped.
However, I seem to have one rogue bug which will not appear in my sprint. When removed from said sprint, it also will not appear in the backlog.
I am now concerned other tickets are not be showing.
All issue types show in my other sprints so unsure why this will not show.
Please advise.
Answer is: When you put a ticket to done, whether that be by work completed, done, closed or whatever, if you re-open the ticket, doesn't matter what you do to it, even with the resolution as 'unresolved' again it will not show in your backlog or sprint.
Clear issue with the system not my set up.
Ugh! you MUST change your workflow to clear the resolution anytime you reopen. If you do this then your issues should appear in the backlog. If they do not then you have something filtering them out.
We do @Jack Brickeywe have open and close screens and its mandatory to change the resolution in either case. As I said in my answer, even if you change the resolution... it still doesn't appear.
Dear @jo astley,
I had a case with a customer, that created a custom resolution named "unresolved". So when they took this one, it looked for the user like NONE but not for Jira,
Just to be sure that it is not the case for your system ...
So long
Thomas
@Thomas Deiler, man you have to love that right! :-)
@jo astley, I can't say I have ever witnessed that and isn't the case in my instance so definitely work w/ Atlassian support.
@Thomas Deilerdefinitely not using any custom resolutions. These are the standard ones on the open/close screens.
Thanks @Jack Brickey I have already raised a ticket with Atlassian support.
Thanks again both
@jo astley, can you provide a snapshot of your board's filter and one of the detail view of the issue in question?
Board filter: project = REG AND resolution is EMPTY ORDER BY Rank ASC
Sprint - as you can see REG-2504 does not appear in the list
Ticket
What happens when I click 'view on board' from within the ticket, despite the ticket clearly being marked as part of a sprint.
If you copy your board filter and use it for a JQL query and in the results you see the one issue displayed then I concur with @Thomas Deiler - build a new board and observe results.
Hi Jack
See my comment above to Thomas. Issue is re-opened tickets never appear in your backlog or sprint. Will raise an issue with support.
Dear @jo astley,
just to be sure, was that rogue bug once on your backlog/sprint before?
So long
Thomas
Hi Thomas, I would have thought so but cannot be 100% sure. It will have certainly been assigned to sprints but before moving to agile we didn't use sprints like we are doing now so I wouldn't have looked to see if it was in the sprint or not as such, we just had a 'current sprint' which was continuous and it would have been added to that.
We are now moving to agile and that is why I have checked to see what is/is not in the sprint and noticed the figures from doing a search and filtering on 'sprint' did not match the figures in the sprint in the backlog. I noted epics do not show but also that this single bug didn't.
Other bugs do.
If bugs in generally are shown than it can be one of the followinf reasons to check
So long
Thomas
As for being previously mapped to another sprint, that could be true but changing the sprint value should surely over come that?
In agile there will always be the odd scenario where tickets that are in the current sprint are not completed or need amends and therefore fall to another sprint when the current sprint ends?
Is there a way to resolve this and get the ticket into the correct sprint.
It is going to be a nightmare if tickets do not even show in a backlog as they will be lost forever... It is only because this one showed when I searched via the main search that it showed up, you shouldnt need to do that with a backlog and board.
Ok,
In your case, I would create a news board that is similar configured (you can delete it later), to exclude a board "error".
If the bug shows up in the new, you can start comparing both.
If not I would perform a "project reindex".
If this does not help, clone the invisible bug and check if its clone is also invisible.
So long
Thomas
Thanks Thomas. Will try creating a new board.
I already tried cloning the ticket and the cloned ticket shows just fine.
As for re-indexing, ATlassian took this function away annoyingly! https://community.atlassian.com/t5/Jira-questions/How-do-I-re-index-if-there-isn-t-an-Indexing-option-in-Advanced/qaq-p/607767
Sorry actually, building a new board might get the tickets to show on the new board but that is still not going to get them into the backlog.
I have compared the backlog with running a general query and there are a total of 20 tickets that are in the project that do not appear in the backlog.
I will look for some commonality between them but super annoying
I have looked at the 20 issues and worked out what the common denominator is. When you put a ticket to done, whether that be by work completed, done, closed or whatever, if you re-open the ticket, doesnt matter what you do to it, even with the resolution as 'unresolved' again it will not show in your backlog or sprint.
Thanks for your help anyway
