A tab to have custom fields with group of radio buttons with subgroups
Vighnesh Pai
October 8, 2024
Hello All,
I'm trying to have a view at EPIC level feature maturity (as EPIC = 1 Feature in my org) in different regions. The catch is, we have single code base for multiple brands (kind of white lable solution) and once implemented, its applicable to all regions.
Now, the testing happens on various regions in different times and it will have external factors which will influence the quality of feature.
I was thinking of having groups of radio buttons in a Tab where we can select either Alpha or beta or whatever the apt state for all brands and all regions i have.
Is this feasible?
Matheus Souza Alves_TitanApps_
Hi @Vighnesh Pai ,
Matheus from TitanApps team here.
I would like to suggest our add-on Smart Checklist for Jira!
You have the possibility to create templates of checklists that can be assigned to your Epics automatically and many other features that could be interesting to your use case.
You can also book a call with us and/or try out the Pro version!
Gracjan Wesołowski _HeroCoders_
October 9, 2024
Hi @Vighnesh Pai
Welcome to the community!
As suggested by @Stephen_Lugton you can use Checklist apps to achieve something similar.
I can recommend our Checklist for Jira Pro, or a Free plugin that allows you to automatically add a checklist. Please see an example here:
You can use Checklist Templates to add it automatically to each Epics. You can choose to either have only checkboxes or checkboxes with statuses.
If you want to know more, you can contact our support here.
Cheers!
Gracjan
Stephen_Lugton
@Vighnesh Pai It would be possible to create custom fields that could then be added into a tab on an epic, but this is one of the few times I'm going to suggest that using a third party app might give you a better presentation (and for the level of information you've asked about there are free reduced feature versions of some of these apps).
In particular I'm thinking about using a checklist to give something like:
