ACP 600 Question
Priyanka khare
Hello ,
I am preparing for ACP 600 and came across this question -
All projects use a simplified workflow which has three statuses (Open, In Progress, Closed) and all global transitions.
You need to find issues which were never In Progress. Select the correct JQL query.
A. Status WAS Open OR Status WAS Closed B. Status != “In Progress”
C. Status NOT Changed TO “In Progress”
D. Status WAS NOT “In Progress”
E. Status ONLY IN (Open, Closed)
what should be the correct answer to this?
Shouldn't it be D?
Regards
Priyanka
2 accepted
3 votes
Ollie Guan
The "WAS NOT" operator is used to find issues that have never had the specified value for the specified field.
Find issues that do not have, and have never had a status of “In Progress”
Priyanka khare
Thanks @Ollie Guan
Jaydeep Chopde November 19, 2020
Thanks @Ollie Guan
Marco Brundel
November 2, 2020
Hi @Priyanka khare ,
I tested it on a Jira Software Server environment.
At A I get the issues that were in the mentioned statuses, but they may also have been “In Progress”
At B I get the issues that are not currently in the “In Progress” status, but they may also have been “In Progress”.
The JQL at C and E are not possible (Error in the JQL Query: Expecting 'IN' but got 'Changed'. Resp. Error in the JQL Query: Expecting operator but got 'ONLY'.)
With D, I do not get issues in the result that were on status In Progress.
So D is the correct answer I think.
regards, Marco
Priyanka khare
Many Thanks @Marco Brundel
Like 2 people like this
Chau Wan Ying Fifi周蘊瑩
April 5, 2021
Hi I came across this question today as well. It said the ans should be status in "open" and "closed", I just dont get it.
