Sign up Log in
AP is not defined
Deleted user March 7, 2017
In an Atlassian connect plugin, we've this code
$(document).ready(function() {
    AP.require('request', function(request) {
which works fine, but sometimes and randomly we receive the error message in the object
AP is not defined
And this is not related to a specific browser or OS
Any idea of why this happens?
Any suggestion on what to investigate?
That's the head section of my web panel
<html lang="en">
    <head>
        <script src="//ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
        <script src="//aui-cdn.atlassian.com/aui-adg/6.0.6/js/aui.min.js"></script>
        <link rel="stylesheet" href="//aui-cdn.atlassian.com/aui-adg/6.0.6/css/aui.min.css" media="all">
        <link rel="stylesheet" href="mycustom.css">
        <script src="mycustom.js"></script>
    </head>
and that's the last part of the body
<!-- Stop the loading addon message -->
    <script id="connect-loader" data-options="sizeToParent:true;">
        (function() {
            var getUrlParam = function(param) {
                var codedParam = (new RegExp(param + '=([^&]*)')).exec(window.location.search)[1];
                return decodeURIComponent(codedParam);
            var baseUrl = getUrlParam('xdm_e') + getUrlParam('cp');
            var options = document.getElementById('connect-loader').getAttribute('data-options');
            var script = document.createElement("script");
            script.src = baseUrl + '/atlassian-connect/all.js';
            if (options) {
                script.setAttribute('data-options', options);
            document.getElementsByTagName("head")[0].appendChild(script);
    </script>
</body>
as described in the Atlassian dev documentation
Michael Eskin
I am running into this exact same issue with loading all.js from our JIRA instance. The script loader is absolutely doing the right thing, we've used it forever for our Confluence add-on and I've verified that it's present and loaded in the DOM. It's all.js that has an issue when it tries to execute.
I'm getting an Uncaught TypeError: Object.defineProperty called on a non-object, and AP fails to be created or made available to our add-in
Gajender Tyagi
December 14, 2021
Uncaught (in promise) TypeError: AP.request is not a function
I'm getting this error and don't know what's wrong, the only difference is I'm running the app in localhost.
Volodymyr Krupach
March 8, 2017
AP is defined in "integration bridge" all.js loaded from your host JIRA:
https://YOUR-ATLASSIAN-DOMAIN/atlassian-connect/all.js
I guess that all.js is not loaded (which should not happen) or maybe your load your custom JS file before all.js.
Deleted user March 8, 2017
all.js is loaded before my custom JS because the code works fine,
and my JS is loaded at last in my web panel
but it seems that sometime (and I don't know when and why)
AP is not available (i.e. all.js is not loaded?)
Like 2 people like this
Volodymyr Krupach
March 8, 2017
Make sure you do no have async attribute in script tags.
Roma Bubyakin _Wombats Corp_
Thanks @Volodymyr Krupach !
It was strange that AP works randomly, but removing async helped.
Dang Thi Thuy Tien
October 7, 2019
Hi @Volodymyr Krupach  ,
I try to add all.js to my plugin but I got this err: http://localhost:2990/jira/atlassian-connect/all.js net::ERR_ABORTED 404
It couldn't load
Do you have any idea about this?
Volodymyr Krupach
October 7, 2019 edited
Hi @Dang Thi Thuy Tien ,
Jira Cloud should NOT be loaded from localhost. You need to get development instance hosted by Atlassian. Here is a good tutorial: https://developer.atlassian.com/cloud/jira/platform/getting-started/
Dang Thi Thuy Tien
October 7, 2019
Thank you so much,
I find some link
<script src="https://connect-cdn.atl-paas.net/all.js" type="text/javascript"></script>
But  It has another error  :
AP.request({
Cannot read property 'request' of undefined
Thank you
Volodymyr Krupach
October 7, 2019
all.js must be loaded from the hosting Jira. It's a bridge between hosting Jira and your app and it will not work when loaded from outside.
Like 3 people like this
Dang Thi Thuy Tien
October 10, 2019
I got it,
Thank you @Volodymyr Krupach
Matti Kiviharju
May 14, 2022
Can you post example how to define properly all.js into scritps? We have 401 authorization error...
Register Now
Upcoming Jira Events
