API PAGINATION JIRA V3
BARBARA EUSEBIO
September 30, 2025
Hello
I have this code here that I'm putting in power bi to get all issues from a project but its giving me bad request. I want all the isues from january 2025 till now. Someone can help me adjusting the code below please?
let
// Parâmetros
url = "https://eci-td.atlassian.net/rest/api/3/search/jql",
email = "xxx",
apiToken = "xxx",
auth = "Basic " & Binary.ToText(Text.ToBinary(email & ":" & apiToken), BinaryEncoding.Base64),
// Função para obter uma página
GetPage = (startAt as number) =>
let
body = Text.ToBinary("{ ""jql"": ""project = CC AND type != Sub-task AND 'customfield_10136' >= '2025-01-01' AND 'customfield_10136' <= now() ORDER BY created DESC"", ""startAt"": " & Number.ToText(startAt) & ", ""maxResults"": 100, ""fields"": [
""key"", ""summary"", ""status"", ""created"", ""updated"", ""assignee"", ""reporter"", ""creator"", ""resolution"", ""duedate"", ""description"", ""issuetype"",
""customfield_10121"", ""customfield_10108"", ""customfield_10136"", ""customfield_10107"", ""customfield_10110"", ""customfield_10111"", ""customfield_10232"",
""customfield_10114"", ""customfield_10208"", ""customfield_10141"", ""customfield_10142""
response = Json.Document(Web.Contents(url, [
Headers = [
Authorization = auth,
#"Content-Type" = "application/json",
Accept = "application/json"
Content = body
issues = response[issues]
in
issues,
// Função recursiva para obter todas as páginas
GetAllPages = (startAt as number, acc as list) =>
let
page = GetPage(startAt),
newAcc = List.Combine({acc, page}),
nextStart = startAt + List.Count(page)
in
if List.Count(page) = 100 then @GetAllPages(nextStart, newAcc) else newAcc,
// Obter todas as issues
allIssues = GetAllPages(0, {}),
// Transformar em tabela
tabelaExpandida = Table.FromList(allIssues, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
tabelaComCampos = Table.ExpandRecordColumn(tabelaExpandida, "Column1", {"key", "fields"}),
camposExpandidos = Table.ExpandRecordColumn(tabelaComCampos, "fields", {
"summary", "status", "created", "updated", "assignee", "reporter", "creator", "resolution", "duedate", "description", "issuetype",
"customfield_10121", "customfield_10108", "customfield_10136", "customfield_10107", "customfield_10110", "customfield_10111", "customfield_10232",
"customfield_10114", "customfield_10208", "customfield_10141", "customfield_10142"
statusExpandido = Table.ExpandRecordColumn(camposExpandidos, "status", {"name"}, {"Estado"}),
assigneeExpandido = Table.ExpandRecordColumn(statusExpandido, "assignee", {"displayName"}, {"Responsável"}),
reporterExpandido = Table.ExpandRecordColumn(assigneeExpandido, "reporter", {"displayName"}, {"Repórter"}),
creatorExpandido = Table.ExpandRecordColumn(reporterExpandido, "creator", {"displayName"}, {"Criador"}),
resolutionExpandido = Table.ExpandRecordColumn(creatorExpandido, "resolution", {"name"}, {"Resolução"}),
issuetypeExpandido = Table.ExpandRecordColumn(resolutionExpandido, "issuetype", {"name"}, {"Tipo de Problema"}),
tabelaFinal = Table.RenameColumns(issuetypeExpandido, {
{"customfield_10121", "Nome da Campanha"},
{"customfield_10108", "Co_Campana"},
{"customfield_10136", "Data de lançamento ou envio"},
{"customfield_10107", "Área/segmentos da campanha"},
{"customfield_10110", "Data início campanha"},
{"customfield_10111", "Data fim campanha"},
{"customfield_10232", "Categoria"},
{"customfield_10114", "Materiais"},
{"customfield_10208", "Segmentos"},
{"customfield_10141", "Contemplar venda"},
{"customfield_10142", "Valor de Cliente"}
in
tabelaFinal
Thank you
Matteo Vecchiato
Hi @BARBARA EUSEBIO ,
Welcome to Atlassian community.
I guess the problem is related to deprecation of Api.
It is required to use the parameter nextPageToken; I sugget to get through this post: https://community.atlassian.com/forums/Jira-questions/Feature-change-during-CHANGE-2046/qaq-p/3103678
Regards
Matthias Gaiser _K15t_
I'd back this answer by @Matteo Vecchiato
Here's the documentation about the API call you're calling and it doesn't contain startAt as parameter anymore.
BARBARA EUSEBIO
September 30, 2025
Hi @Matthias Gaiser _K15t_  and @Matteo Vecchiato
Thanks for you fast feedback :)
Do you know if power bi supports that oarameter nextPageToken?
Barbara
Matteo Vecchiato
I know from other contacts that they manage to get the integration with Powerbi with the new api.
