API token expiration notification configuration
David Whitlock August 28, 2025
My question is specific to the Service Accounts that we can create in Atlassian Cloud. When we create an expiration for a particular token, let's say in a year. Does Atlassian Cloud send us a reminder 30-days from the time that token is to expire? Or do we have to manage the notifications ourselves?
Thank you
Matteo Vecchiato
August 28, 2025
Hi @David Whitlock
Thank you for your question. I'm afraid that there isn't a reminder for admins. The notice is sent directly to the personal email, for service accounts is not clear.
There is a request about it: https://jira.atlassian.com/browse/ID-8781
In our case, we manage the reminder in other ways, setting a future task with automation for instance.
Hope it helps
@Matteo Vecchiato thank you for that response, it is what I was expecting. Do you know if there is an API endpoint we can use that lists the PAT in an organization along with the expiration dates. If so, I can schedule my own task to send myself reminders
Matteo Vecchiato
August 28, 2025
Hi @David Whitlock , I never used it, there is an API to get all the tokens in the organization: https://developer.atlassian.com/cloud/admin/api-access/rest/api-group-api-token/#api-group-api-token
It is possible to filter by user and several parameters.
It is required the organization ID as parameter, you can get it through https://confluence.atlassian.com/cloudkb/retrieve-my-atlassian-cloud-organization-s-id-1207189876.html
Regards
