Ability to select multiple epics in Epic Panel
Arjun March 31, 2015
We use the JIRA Agile views in our workflow and we really find it useful.
On the epic panel, if I select 'All Issues' then I see that the filter takes into account issues from all epics.
And if I select one Epic it will filter issues based on that particular Epic.
Is it somehow possible to select 3 or 4 related Epics and see the issues based on only those?
This would be a really useful feature in our workflow. We would like to see the sprints that are planned for a set of related epics.
cgauterio
April 7, 2015
Hi Arjun,
I'm afraid that's not possible just yet. I took the liberty of creating an improvement on your behalf: https://jira.atlassian.com/browse/GHS-11937
Please add yourself as a watcher to be notified of future updates.
Clarissa.
Nicolas Sigalo
October 6, 2015
It would be nice to have the same thing for version in the version panel as well. Could you create a improvment for that ? Regards, Nicolas
paulwinfield
September 13, 2016
This seems like a fairly basic, yet much used function?  Why can't this be added?
Rene Bartkowiak
January 13, 2017
What is the current status here? I still can't select multiple epics.
Prem Chudzinski [extensi]
hi @Arjun@Rene Bartkowiak@paulwinfield@Nicolas Sigalo@cgauterio
You can use the Agile Board Filter addon to do that
Use the filtering bar (doropdowns or JQL) to filter out issues or live serach to filter out the epic panel.
