About Database custom field, crypt password of DB Connection
j
Is there a way to encrypt the password of a connection in context.xml file?
Silviu Burcea
September 25, 2014
This is already answered here: http://bugs.kepler.ro/browse/DBCF-119. In short, it is not possible, and if someone has access to the context.xml file, you have bigger security issues.
It is possible to encrypt the password, but you will have to write a custom factory that will decrypt the password on the Tomcat's side, but again, if an attacker has access to your Tomcat, he can decompile your factory class to access the actual db password.
To sum up, restrict the access to your Tomcat/JIRA instance, it's far easier, cleaner and safer way to secure your system.
Best regards,
Silviu
