Instead added a simple instruction by adding %% CURRNET_USER %%. in this case, I want to add user at custom field. For example the field "supporter". But I don't know what the command or JQL is like. please help me
Welcome to the Community :)
I'd suggest doing this via Automation in Cloud, rather than a Post Function.
For example, to add the creating user to the field "Supporter" after an issue is created, you could:
Let us know if this works for you, or if you'd like more assistance with your specific scenario, please provide more details!
Ste
Thanks for your answer.. I used "Automation" function and it worked. I find this function useful
Hello, in the case of this postfunction which is "Update custom field value" you cannot enter other values similar to %% CURRNET_USER %% or %% CURRENT_DATEANDTIME %%. If what you need to do is copy the value of another user type field into a custom field, I recommend using the postfunction "Copy Value From Other Field"
Thanks for your answer. I don't use this function anymore. I use the other is automation function
@Juan Manuel Ibarra there is also a note for cascading fields there in Post Function for the workflow:
For Cascading Select fields, you can use either the value or the id of the option to be selected.
But in which format shall I put the option ID there? I have
customfield_11803
context = 13317
parent option ID = 12486
child option ID = 16019
So, shall I put just 16019 to apply for the field, or should it be smth like option_16019, or 12486/16019 ?
