Access Jira Cloud REST API using 2-legged OAuth
Pascal Houde November 5, 2018
I want to build an application that will retrieve Jira issues from different cloud instances in order to get some kind of aggregated view of all Jira issues that are dispersed on those different instances. We have many developers working for different customers each owning their own Jira cloud instance. We want to provide via a centralized app an harmonized view of all Jira issues assigned to each of our developer. Some of them can work for multiple customers at the same time.
I don't want to have user interaction required like in a 3LO Oauth. I want to fetch that information on a regular basis so it is basically a server to server approach with a web dashboard that will expose that information.
Am I forced to use Basic auth for that? The doc begs people to stay away from Basic Auth because it is not as secure as OAuth but at the same time does not provide alternative for my needs.
Raimundas Juska
November 5, 2018 edited
Atlassian Connect has the best documentation regarding this so I would go that path - https://developer.atlassian.com/cloud/jira/platform/authentication-for-apps/
Pascal Houde November 7, 2018 edited
I generated a JWT token using the shared secret that was provided after registering my app in Jira Connect but getting back HTTP 401 on requests I make. Also I receive back HTML content in the response even though I specified application/json. This happens if I specify JWT <my jwt token> in the authorization header. If I specify Bearer instead of JWT then I get back JSON message "Client must be authenticated to access this resource." but still a 401.
I don't know what I am missing.
I was missing the query string hash (QSH) but still having the same problem. It would be nice to know what is wrong when developing instead of just receiving a 401.
Raimundas Juska
November 7, 2018
You won't get more info on 401 as providing more info on what exactly is wrong would be a security flaw.
What language are you using on your server? I know that there are packages for a few languages, try searching for your required language.
Node.js - https://www.npmjs.com/package/atlassian-connect-express
Python - https://bitbucket.org/atlassian/atlassian-jwt-py?_ga=2.116449987.458870543.1539531922-190871020.1538306682
Using .net. There is already a developer mode in Jira for installing connector that are not on the market place. It would be therefore possible to provide more information in this context.
There could be something that is wrong when I generate the QSH or something wrong with the JWT itself. I am using Microsoft classes to generate the jwt token.
Raimundas Juska
November 8, 2018
The way I am using jwt is adding it via query string at the end of rest request (?jwt=) and it works fine.
This link describes the detailed way of creating jwt - you need to create query string hash (using request method, original URL and query string), then create token itself using query string hash, addon key, and iat/exp dates.
https://developer.atlassian.com/cloud/jira/platform/understanding-jwt/
https://developer.atlassian.com/blog/2015/01/understanding-jwt/
I also see that Atlassian recommends using this package for .net - https://github.com/johnsheehan/jwt
I have also found this - https://bitbucket.org/atlassianlabs/atlassian-connect-.net
Pascal Houde November 8, 2018
Finally found the issues with my code.
1) Was not using UTC time.
2) Was not setting "iat" claim. The MS library is not setting it automatically.
I am passing "Jwt {jwt token}" in the Authorization header and it works fine.
It seems to be much less trouble using POST instead of GET because I don't have to deal with the QSH. The doc does mention about integrating POST data in the computation of QSH but I don't and it is working. Perhaps it is meant only for x-www-form-urlencoded??
In parallel, I developed a OAuth 2LO which is working fine. I don't have to deal with QSH when using OAuth but I need to use impersonation in order to make requests.
Thanks all for your help and support.
Register now
