Active Sprint Vanished/Disappeared/Deleted from Jira
Florent Plomb November 16, 2024 edited
Hi All,
I was working on my sprint, and it suddenly disappeared without any apparent reason. The trigger seemed to be a bulk edit on tasks to move them to the active sprint “NOV-A-24 Neptune #2,” after which the sprint completely vanished from Jira!
After checking the System -> Audit log -> this is clear somehow I deleted the sprint, so end of the story.
November 16, 2024
Hi @Florent Plomb -- Welcome to the Atlassian Community!
Have you asked your Jira Site Admin to review the global audit log to check who / what deleted the sprint?
https://support.atlassian.com/jira-cloud-administration/docs/audit-activities-in-jira-applications/
Marc - Devoteam
November 16, 2024
Hi @Florent Plomb
Can you search your sprint, JQL: sprint = <sprint_name>
Does this come back with a result?
There's nothing with JQL :/ . I'm going to try getting data from the API to see if I can find a trace, but honestly, it’s exactly as if the sprint was intentionally deleted—you can’t recover it.
Marc - Devoteam
November 16, 2024
Hi @Florent Plomb
Also check the instance global audit log, as mentioned by @Bill Sheboy
