currently we meet one wired problem that our one project Activity Steam is lot when we click "Show More" more than twice, but refreshing the page shows the data again. the other projects activity streams are fine. could you please help us on this? thanks in advance!
Best,
Zhen
Hi Zhen,
The Activity Stream function can also be used in the Dashboard, where the question of whether or not to also have the same?
Hi ille, thanks for your quick reply. I will try it later to see whether the activity stream on dashboard has same problem and will let you know the result. much thanks!
Hi Ollie, activity stream on dashboard is fine. do you have some ideas about this problem? thanks
Reindexing also does not work. anyway, thanks for your help.
