Add Status Issue Backlog Item
Alvin Leroy Steagall August 9, 2022
How can I add the status´issues (Done, Test..) for view this status in backlog ?
2 accepted
Thuan, Do Dang
August 9, 2022
Hi @Alvin Leroy Steagall ,
You can custom your backlog card layout in board config
And then your backlog looks like this
Hope this helps!
Alvin Leroy Steagall August 10, 2022
Thank you very much !!!!!
Like John Funk likes this
John Funk
Hi Alvin - Welcome to the Atlassian Community!
No, you won't be able to add other columns here. The thought is that if it is in the Backlog, then it's only in one status, so that doesn't need to be shown.
You should create a filter with the columns you want to show and place a link to it in the Shortcuts section on the left.
Thank you very much
FREE
