I want to validation on our custom fields like Pricing fields should only accept value between 5000 – 8000 otherwise give error “Value should be between 5000-8000”. How I can achieve this requirement on Cloud?
Please help.
Best Regards
Dishant
Hi Dishant,
I believe the only way to achieve that in JIRA Cloud is by using the Value Field condition (it is provided by the JIRA Suite Utilities add-on). In this case, you would have to add two conditions: one for values greater than 5000 and another one for values less than 8000.
I hope this helps.
Clarissa.
