I would like to add some standard template text (ideally in the description field) to Story type items for our project.
I do not want to use a marketplace app and I'd rather not use automations/change workflow.
How can default text be added to this field please?
Hi @Max Russell
Welcome to the Atlassian Community
You can try setting the value using automation rules.
When "Issue Created" trigger
IF : Field Condition as Issue Type: Story
Then Action: Edit Issue> Description and set the value as required.
