×we need add one custom buuton at bottom of pop-up box.
such as
What should I do to achieve it
you can contact me through email:
247546670@qq.com
Hi Yongjian - Welcome to the Atlassian Community!
You will not be able to add a button there.
very glad to receive your reply.
You mean it's not implementable?
Can't plugins do it?
Check out ScriptRunner and other similar tools. They are able to give you options to modify the behavior of Jira and also to add a button. But you need some coding skills and you can´t do all. Even the tools are limited.
