Add a document to a automatization
Daniel Del Ordi Garcia December 20, 2024
in an automation that I have created, who when I trigger it manually can attach a file as user input, is this possible?
Jack Brickey
Hi @Daniel Del Ordi Garcia ,  welcome to the community.
While automation does support "prompt for input" on a manual trigger, attachments is not one of those options, unfortunately. Maybe you could explain in more detail your used case, and what you're trying to accomplish to see if there's an alternative approach.
Daniel Del Ordi Garcia December 23, 2024
I wanted to send an email automatically when a issue transitioned a specific state. When these happen, i need to add to this email an attachment with other Issue's elements.
So the workflow will be: Transition to a status, the automation runs, it ask for a file to attach at email and it send the mail with the file.
Jack Brickey
Understand but the automation can't ask for a file.
Like Aron Gombas _Midori_ likes this
@Daniel Del Ordi Garcia See if the Better PDF Automation app works for you!
With this app you can create an automation rule that:
  1. is triggered by an issue transition,
  2. will generate a PDF document of another issue,
  3. ...and send a custom email with the PDF document as email attachment!
The rule will look something like this:
Just follow this tutorial!
(This app is developed and supported by our team.)
Thank you for the information! Your application is really good, but I don't think it meets my requirements. I need to attach a specific file to an email.
So, automation rules are executed in the background. They cannot provide the UI to upload the file.
