Add a template to a subtask and bugtask
M. Gabriela Labastidas
December 17, 2023
In our team, we are using the app "Default values for 'Create Issue' screen" to be able to create templates for most issues (initiatives, epics, stories, bugs). However, this app doesn't seem to support sub tasks and bug tasks inside an existing story/task/bug.
Does someone knows a way to do this? It doesn't need to be this app necesarily, we are looking for a general way to achieve this
Thank you
Luka Hummel - codefortynine
Hi @M. Gabriela Labastidas
If you are willing to use a third-party app, you could try our app Deep Clone for Jira. While the primary function of Deep Clone is to clone issues and their configurations, it can also be used creatively to achieve a template-like functionality for sub-tasks and bug tasks. Here’s how you could use it:
1. Create Template Issues: First, set up a template issue for each type of sub-task or bug task you frequently use. These template issues should include all the fields, descriptions, labels, etc., that you typically need.
2. Use Deep Clone to Duplicate: When you need to create a new sub-task or bug task, use Deep Clone to clone the corresponding template issue. Deep Clone allows for cloning into the same project or even into different projects and maintains the configuration of the source issue.
Paul Pavlovsky_AppLiger_
Hi @M. Gabriela Labastidas 👋
Feel free to try out our Easy Issue Templates for Jira! Create Jira issues from dynamic, structured templates. Restore entire Epics with sub-tasks, related issues, and all child elements.
Check out our wiki for more info and reach out if you would have more questions.
Pavel from AppLiger
Aleksandra Bosacka _Deviniti_
Hello @M. Gabriela Labastidas
Alternatively to automation, you could also use our Issue Templates for Jira app to create different kinds of templates (e.g., bug reports or feature requests) and then apply them when creating new issues in your projects and pre-populate field values. Those templates are available to users on the Create issue from template screen, or via post function that can be easily added to your sub-tasks workflow.
Apart from the post function, you can always apply a template to an existing sub-task using the Apply template option under the three-dots menu in the issue.
For more details about supported use cases, I encourage you to see our documentation  I’m sure you will find it useful!
Aleksandra
Megha Rajanna
December 17, 2023
When
Issue Transitioned
From To Do
To In Progress
If
Issue matches conditions
Project = "Your Project"
Issue Type = "Story"
Then
Create Issue
Issue Type = "Sub-Task"
Summary = "Default Summary"
Description = "Default Description"
Assignee = "{{issue.assignee}}" // You can use smart values for dynamic data
Help us plant more trees
