Add comment and Do Transitions via rest api v3
Rajesh Ale February 10, 2022 edited
"update": {
"comment": [
"add": {
"body": {
"type": "doc",
"version": 1,
"content": [
"type": "paragraph",
"content": [
"text": "Hello There!!",
"type": "text"
"transition": {
"id": "71"
Above request works with rest api v2, any idea how to make it work for v3  .giving 204 message and adding comment . but ticket is not getting transitioned.
Pramodh M
@Rajesh Ale
It works only when you have a screen while transitioning the issue!
Using the comment or any other field to update the field while transitioning the issue is redundant
Place the transition screen in workflow to work
cant we do both at same time  using edit issue or update issue ??
Pramodh M
@Rajesh Ale
For transitioning Issues, you need to get the transition ID first and then perform the transition
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-transitions-get
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-transitions-post
curl --request GET \
--url 'https://your-site.atlassian.net/rest/api/3/issue/WSP-198/transitions' \
--user 'email:token' \
--header 'Accept: application/json'
Get the Transition ID from above Response
curl --request POST \
--header 'Accept: application/json' \
--header 'Content-Type: application/json' \
--data '{
"transition": {
"id": "51"
Let me know if you have any queries
Pramodh
I guess you haven't read my question am trying to do both adding comment and do transitions at the same time .. not just adding comment
Thanks for your comment
Pramodh M
Hi @Rajesh Ale
This works for adding comments to an issue
--url 'https://your-site.atlassian.net/rest/api/3/issue/WSP-198/comment' \
--data '{
"body": {
"type": "doc",
"version": 1,
"content": [
"content": [
"type": "text"
Reference here
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-comments/#api-rest-api-3-issue-issueidorkey-comment-post
